2002 Escalade base wiring problem
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2002 Escalade base wiring problem in Cadillac Escalade Forums; I finally had a chance to get my 2002 into a shop that had a scanner to try and see ...
    gentz777 is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Sep 2013
    58
    15
    I finally had a chance to get my 2002 into a shop that had a scanner to try and see what codes are coming up for the dreaded service stability system light.everything has been replaced with new, shocks, compressor, etc.
    just can't get the light to go off. He tells me I have no service codes popping up and it appears to be a broken wire somewhere from the back end to the dash.
    (that really narrows it done!) would anyone know where I can get my hands on a wiring diagram?
    I can't spend hundreds of bucks buying the sevice manuals like ones you see on E-Bay.
    This is something I will have to trouble shoot myself just basically checking wires in the harnesses I guess. Big bucks for time if taken to shop or worst yet the dealer..
    Or even if someone could give me a suggestion as to where to start? I can do continuity tests. I have a few ideas.. just need to know what harness to look for first. I'll start at the compressor harness and work my way to the front i would guess.
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    I sent you a PM with some useful info...
