2005 Cadillac Escalade Rear Differential Capacity???
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2005 Cadillac Escalade Rear Differential Capacity??? in Cadillac Escalade Forums; http://www.amsoil.com/mygarage/vehic...LAC+ESCALADE+T It says the 8.6 Ring Gear Rear only has 4.2 Pints (2.1 Quarts) . On the rear differential tutorial ...
    Lepper is offline Cadillac Owners Member
    Automobile(s): 05 Escalade
    Mar 2014
    Savannah
    22
    It says the 8.6 Ring Gear Rear only has 4.2 Pints (2.1 Quarts) . On the rear differential tutorial on here, the guy said he got 6 quarts in there? Am I confused about something? I am also confused about the intial fill vs total fill on the transmission fluid. Does it hold 5 quarts or 11.2?
    4.2 pints seemed very little?
    2005 Cadillac Escalade 5.3L 2WD.
    BIG-KO is offline Cadillac Owners Fanatic
    Automobile(s): 2003 escalade
    Mar 2014
    CHAMBERSBURG,PA
    50
    103
    Re: 2005 Cadillac Escalade Rear Differential Capacity???
    2.1-2.5 QT is correct. transmission fill after filter or pan removal should be around 4.5-5 qts. total fill after trans rebuild with empty torque converter should be around 12 qts.
