06 escalade tranny 2-3 shift flair
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 06 escalade tranny 2-3 shift flair in Cadillac Escalade Forums; Hey all new to the forum having a problem with my tranny shifting from 2-3 gear i bought a rebuilt ...
    joeyb418 is offline Cadillac Owners Member
    Automobile(s): None
    May 2014
    None
    23
    Hey all new to the forum having a problem with my tranny shifting from 2-3 gear i bought a rebuilt tranny and the problem is still there any suggestions would be great
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Was the fluid topped off right?
    Automobile(s): None
    May 2014
    None
    23
    Yes it was at the right level on the original trans
    Which I did a fluid and filter change on, now with the rebuilt trans I put in it still has the same issue.
    Could it possibly be something with the PCM
    BIG-KO is offline Cadillac Owners Fanatic
    Automobile(s): 2003 escalade
    Mar 2014
    CHAMBERSBURG,PA
    50
    104
    Re: 06 escalade tranny 2-3 shift flair
    If you replaced your old failing trans then there is likely "TAP" codes set in the computer. TAP stands for Transmission Adaptive Pressure. If the computer sensed the shifts were taking too long, pressures weren't right or any various parameters then the computer "tries" to fix it by jacking the pressures or adapting shift. Get to a trans shop or dealer to have these codes deleted so the computer can learn all over how the new trans behaves. I hope you flushed your trans cooler and lines, if not then you could have sent debris into the freshly rebuilt valvebody and caused problems. See this kit: http://www.ebay.com/itm/SUPERIOR-SHI...item1c3b0a14ce. on ebay . I have used this kit to fix or improve the 1-2 and 2-3 shift in the 4l65e trans with very good results.
    Automobile(s): None
    May 2014
    None
    23
    Thanks for the info and yes I did flush the cooler lines then blew out the lines with air
  8. Remove Advertisements
