02 Escalade Starting Running Loud
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 02 Escalade Starting Running Loud in Cadillac Escalade Forums; Hi - I noticed about a week ago when I start up my Escalade there is a loud constant noise. ...
    carguy45 is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Jan 2012
    39
    9
    Hi -
    I noticed about a week ago when I start up my Escalade there is a loud constant noise. I have replaced the belts about 1 month ago and it was extremely quiet after this job. It sounds like air is being sucked in at a large volume but I'm not seeing any holes, leaks (other than the oil under the vehicle but that one is about 6 months old), or other visual cues as to the issue. The vehicle is working fine with no change in performance other than the tranny temp was at 200 the last time I drove it vs. the usual 150-180 range - I'll chalk it up to all the stop / go traffic I was in here in Orlando. Just wanted some help to see if I should be worried at the change and if there any clues folks on here can provide to point me in a direction to investigate.
    2002 Escalade
    146,500 miles
    Thanks for the help !
    Mike
    BIG-KO is offline Cadillac Owners Fanatic
    Automobile(s): 2003 escalade
    Mar 2014
    CHAMBERSBURG,PA
    50
    102
    Re: 02 Escalade Starting Running Loud
    The 6.0 engines in our Escalades are very prone to exhaust manifold bolt breakage. When the head of the bolt pops off then the exh manifold leaks and causes a loud ticking sound. I know that's not what you described but maybe that is the problem. Look at each side and count the bolt heads attaching manifold to the head there needs to be 6-per side. Now, don't count the smaller bolt heads that attach the heat shields to the manifold.
    Jan 2012
    39
    9
    I'll have to look at those tomorrow. Is there any issue with driving - say 30 or 40 miles round trip?
    I had a chance to go out and look at the manifold bolts - all of them are present and accounted for. Appreciate the response as when I looked online for it I didn't know what an issue it was for our Escalades.
  5. #4
    Mar 2014
    CHAMBERSBURG,PA
    50
    102
    Many people drive for years with a leaking exh manifold and just learn to live with the ticking noise.
  6. #5
    Jan 2012
    39
    9
    Just wanted to update on this one. It was the tension pulley for the drive belt as I was driving and the car essentially died. In looking at the pulley it appears it became stuck and the friction of the belt dragging on it basically melted it. Tossed on a new one and drive belt and it's quiet as a church mouse again. Appreciate the quick answers when I first posted it.
    Mike
  7. #6
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Thanks for the update, it helps us all to hear what it was.
  8. #7
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by carguy45
    Just wanted to update on this one. It was the tension pulley for the drive belt as I was driving and the car essentially died. In looking at the pulley it appears it became stuck and the friction of the belt dragging on it basically melted it. Tossed on a new one and drive belt and it's quiet as a church mouse again. Appreciate the quick answers when I first posted it. Mike
    Wow and I thought my ac tensioner was bad(it was really) when I had mine replaced(it would bang at times and I would feel it in the floorboard)
    I wonder if I need to check mine again before summer hits full swing(note to self check ac belt)
  9. Remove Advertisements
