Oil filler
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Oil filler in Cadillac Escalade Forums; How is the oil filler held into the valve cover on the 6.0? It seems a little loose and I ...
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Oil filler
    How is the oil filler held into the valve cover on the 6.0? It seems a little loose and I think it may be leaking at the base a bit. The valve cover has a black coating of oil/dirt on it. Is there a gasket or O-ring that seals it?
    BIG-KO is offline Cadillac Owners Fanatic
    Automobile(s): 2003 escalade
    Mar 2014
    CHAMBERSBURG,PA
    50
    104
    Re: Oil filler
    Yes there is an o-ring at the base where it goes into the valvecover. Cant remember if it's avail separetly, see the dealer, or go to auto parts store and buy a cheap cap and rob the o-ring off it to replace on to your original tube.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Oil filler
    Thanks!
    How does the filler come out of the valve cover? Does it pull straight out or twist counterclockwise? I don't want to break it!
    Mar 2014
    CHAMBERSBURG,PA
    50
    104
    Re: Oil filler
    Twist it out/off just like you would the oil fill cap. Would probably help if you took the black plastic valve cover shield off. Grab a can of carb cleaner at the store too so you can spray off all the oil goop and residue. If you have never had the covers off I believe it is an 8mm. Top center of the upper cover is 1 bolt. Remove the upper intake cover first to reveal the other bolts to get the rh cover off.
  7. Remove Advertisements
