Service ride control message
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Service ride control message in Cadillac Escalade Forums; Hello, My 2004 Escalade ESV has completely bottomed out in the back and the air compressor runs a lot. The ...
    HoganPC is offline Cadillac Owners Member
    Automobile(s): Escalade 2004 ESV
    May 2014
    45
    1
    Hello,
    The ride is getting worse and it now bottoms out over most all bumps.
    I went to my local auto parts store and they said that two types of air shocks are available, how do I find out which one I need?
    Are there any other things I should look into before I replace the shocks?
    Thank you in advance for your thoughts.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    It depends on how you like the stock auto ride system
    Some members swap the stock shocks for gas shocks
    Others(like me) replace the stock shocks and compressor and keep the stock auto ride system
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Service ride control message
    Or get passive air shocks like those from Arnott and keep the air ride without the OEM cost.
    SFX Group's Avatar
    SFX Group is offline Cadillac Owners Enthusiast
    Automobile(s): None at the moment
    Aug 2007
    Cambridge, ON
    43
    561
    Mine has this up, ive just replaced all 4 TPMS senders on the wheels (IPM i think they where), $290 (Canada) for all parts and wheels, removed, balanced and put back on (and programmed).
    I only have the Ride Control message now. My compressor works, i need to look at the codes, but i want someone else who knows where there doing.
    I know the compressor was replaced, but the message has been on since then, so i might just get another compressor.... will look in to it, the message drives me nuts!
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Along the same topic, do the Arnott rear shocks function exactly the same as OEM? It looks like the Arnott FRONT SHOCKS have a gadget that plugs in to fool the ride control system.
    The new (not rebuilt) Arnott REAR SHOCKS look like they have the same air inlet plug in and the same wiring pigtail plug in built into the shocks (ie,they appear to be just like OEM). So do the rears work the same, because the fronts seem to use some electronic tom foolery. Just what does the two wire electrical plug on each rear shock do?
    Arnotts website isn't really clear on if their rear shocks function the same as OEM.
    SFX Group's Avatar
    Aug 2007
    Cambridge, ON
    43
    561
    Ive had a look at the wiring....
    There is a controller (under rear HVAC), each damper has a sensor (front and rear), each wheel has a suspension height sensor (front and rear, mopunting on the chassis with a link to the arm / axle) then a pump with a pressure sensor.
    So this means for the complete unit to work, all 4 shocks need to be plugged in and the positoins sensors need to work, need to pull codes, and check if cables are in i would think.
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    Ok, that makes sense. From what I can see reading further on Arnotts site, the new and rebuilt rears do interface with the electronic dampening but their fronts do not. I am thinking of going with new rears from Arnott and probably OEM for fronts which I assume are AC Delco.. I just put in a new compressor assembly made by Dorman.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Retrax
    You are correct on the oem
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    TCM,
    AC Delco lists several different part numbers for my 2003 EXT. Any idea on where I can find the right number? I might just try to call them on Monday. It looks like I can probably get them online through Amazon for about $225 for the OEM fronts compared to $214 for the Arnott fronts.
    SFX Group's Avatar
    Aug 2007
    Cambridge, ON
    43
    561
    Quote Originally Posted by Retrax View Post
    I read somewhere that some make (on Amazon) was trash, however i cant remember which, i do remember it needs to have the OEM plug, they seem to be ok, its the ones with loose wires you "tap" in to the truck harness tend to fail after about 6 months.
    TCM,
    I go to the dealer, talking about how good the truck is then ask for a quote for parts with my VIN number, i walk out 10 mins later with a written quote AND PART NUMBERS
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    Good idea. The dorman part is a complete replacement just like the OEM part. It also had a lifetime warranty. No wires to splice. Here's a pic of what I got.
    SFX Group's Avatar
    Aug 2007
    Cambridge, ON
    43
    561
    Do you have a dorman part number?
    Mine was done 3 years ago, however i am hoping he didnt cut any wires off, also i will be making a "protection" cover as i am sure when i looked at this its right next to the rear left wheel, about the distance it takes to cover it every bit of water the wheel flicks off (including salt).
    I think my problem are the shocks, i notice the front ones are yellow, they cant be OEM!
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by SFX Group
    Do you have a dorman part number? Mine was done 3 years ago, however i am hoping he didnt cut any wires off, also i will be making a "protection" cover as i am sure when i looked at this its right next to the rear left wheel, about the distance it takes to cover it every bit of water the wheel flicks off (including salt). I think my problem are the shocks, i notice the front ones are yellow, they cant be OEM!
    Amazon sells them for a great price just keep in mind the for my car feature on the site doesn't work for stuff like this
  16. #14
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    Here's the part number for my truck (2003). 2007 and later used a different plug and use a different part number. I know this one will at least fit 2003-2006.
  17. #15
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    Ok, to follow up with anybody wondering, I just got off the phone with Arnott. Their web site reads like their shocks use the factory electronic connector to interface with the shock but they do not. The guy I spoke with said the plug on the rear shocks are basically a resistor to fool the vehicle into thinking the factory shocks are installed. He did say they have heard good feedback of their product.
    It looks like the only way to maintain the factory speed dampening is to go with the OEM parts front and rear. I don't know how much of a difference a guy could feel between the two but there is the answer anyway.
  18. Remove Advertisements
