05' escalade ESV with 80,000 miles and need to add 40-100 H.P.
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05' escalade ESV with 80,000 miles and need to add 40-100 H.P. in Cadillac Escalade Forums; Recently bought and will do some towing. If gas mileage is made better budget could be higher. Looking for any ...
    Withapict is offline Cadillac Owners Member
    Automobile(s): Escalade and cts
    May 2014
    43
    4
    Looking for any suggestions.
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Re: 05' escalade ESV with 80,000 miles and need to add 40-100 H.P.
    You likely won't see a mpg increase. 40-100 hp is a pretty tall order. It's not going to happen with a cold air intake, programmer and performance exhaust system. What is your budget? If you put in a performance cam, new heads, intake, along with a performance tune and free flowing cats and exhaust you could probably pick up 75 horsepower but you are talking a lot of money. To gain 100 or more you should look into a supercharger, larger fuel injectors, performance exhaust and tune.
    If you are looking for an SUV with better mpg and towing power you would be better off getting a suburban or excursion with a diesel. You can make some pretty impressive power gains with just a tuner.
    Jophusp's Avatar
    Jophusp is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac Escalade XS-500
    Nov 2012
    33
    102
    I agree with Retrax. Opening up the airways, and a tune could get you up to around 26hp, or so I have heard. If your looking for big gains, try a bigger fuel pump, injectors, and supercharger. A centrifugal setup is not all that hard, or expensive, and there is lots of room to play with them. I have a 9lb powerdyne, and get 550hp +.
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    Jophusp,
    What do you figure you have into parts on that setup (injectors, fuel system upgrade, blower, engine management programming, exhaust?). Can you run 9psi on pump gas without any detonation? Are you using stock heads? Any concerns with valve float?
    Your truck sounds pretty sweet! Superchargers and turbos are awesome. I recently sold my big block 67 Camaro RS SS. It had a 10.5:1 Gen V full roller with a pro shot direct nitrous system (one nitrous and one fuel nozzle on each intake runner). I owned that car for almost 20 years. If I started a new project, forced induction would be the way to go.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    What are you towing that you need more power? What engine do you have? If you really want the power, a supercharger would be the way to go!
    Jophusp's Avatar
    Nov 2012
    33
    102
    Quote Originally Posted by Retrax View Post
    Jophusp,
    My truck is actually an XS-500, but I have upgraded the blower. It was a 96k truck from the dealer. There were different levels of performance that you could get, right now I have the Blower, larger injectors, Bigger fuel pump, reprogrammed computer, Borla dual exhaust, baer brakes, and a corvette servo to stiffen up my shifts. sounds beast! I also added a blow-off valve instead of the recirculating valve, just for the fun of hearing that loud PSSSSSH! coming from an escalade. I run Shell 93 religiously. Have not had any problems, except Im getting new bearings in the blower again after only about 10k miles, I did drive it a little hard from time to time, but I love shocking people.
    I would love to get my hands on a 67 Camaro Bet that was a blast to drive!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Jophusp
    My truck is actually an XS-500, but I have upgraded the blower. It was a 96k truck from the dealer. There were different levels of performance that you could get, right now I have the Blower, larger injectors, Bigger fuel pump, reprogrammed computer, Borla dual exhaust, baer brakes, and a corvette servo to stiffen up my shifts. sounds beast! I also added a blow-off valve instead of the recirculating valve, just for the fun of hearing that loud PSSSSSH! coming from an escalade. I run Shell 93 religiously. Have not had any problems, except Im getting new bearings in the blower again after only about 10k miles, I did drive it a little hard from time to time, but I love shocking people. ---------- I would love to get my hands on a 67 Camaro Bet that was a blast to drive!
    Man you have a beast of a truck
    I also would have the blow off valve
    10k on the blower seems short on the bearings to me
    deathpulse is offline Cadillac Owners Member
    Nov 2012
    46
    76
    This truck is a pretty good truck to tow with in normally aspirated form. What are you going to tow? Honestly, if you want to tow something larger than the stock truck can handle, I'd look into a nice used diesel heavy duty truck before getting a power adder (super/turbo charger) for the 'Lade. Using a power adder for towing on your escalade will also wear hard on your transmission, engine internals, fuel system etc. which will also need to be at least considered for upgrade (which is why I am suggesting thinking about a used heavy duty diesel).
    May 2014
    43
    4
    Assume I start with long term plans of a supercharger I still would assume a handful of mods are still needed. Chip, intake, exhaust ext.
    Are things like valves and cam also needed?
    Supercharger I would assume totals 7-10,000$.
    Could I come close to 40-50 h.p. For under $3000 or so?
    I just pulled a 16*8 enclosed trailer 200 miles with maybe an additional 1500 pounds inside. and was ok. Also have a 30' camper.
    Ballpark price I would be looking at to get to your 550 h.p.?
    Jophusp's Avatar
    Nov 2012
    33
    102
    Depending which type supercharger you would go with. A centrifugal one like mine only cost about $1500. Roots type would be a little more. for the whole kit, you would probably never pass 7k. I think most kits come with new intake, but if not, just rig one up, its pretty easy. Most kits would also come with the larger injectors, and the programming needed to re-tune. Exhaust would be up to you after that, but there are lots of options out there. Headers would be nice, but are not needed. For 550+ HP You will need to be making at least 7lbs of boost. On one run with 9lbs I hit 596! With our LQ9 engine, the Valves, and cam are fine, but you will also need a bigger fuel pump. As far as mileage goes, I get 9-12 city, 17-19 Highway.
  13. Remove Advertisements
