oil pressure
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, oil pressure in Cadillac Escalade Forums; 2002 escalade 6.0L AWD. The oil pressure is at 40 during idle but when i accelerate the pressure goes all ...
    drewusmaximus is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Escalade
    Jan 2014
    98
    oil pressure
    2002 escalade 6.0L AWD. The oil pressure is at 40 during idle but when i accelerate the pressure goes all the to almost 80.
    And i"m hearing a flutter when i accelerate. No loss of power just the flutter sound when accelerating. Any thoughts? I was told It might be the heat shield but when i saw the oil pressure gauge go up I got concerned. Hopefully someboddy can give me some insight.
    Thanks in advance!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Sounds like the sender unit is failing
    The fluttering noise is possible the muffler heat shield weld broke
    Jan 2014
    98
    Re: oil pressure
    How about the oil pressure going from 40 to almost 80 when accelerating? I'm worried there might be something wrong with one of the cylinders
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What's the problem? Oil pressure rises with RPM.
    And cylinders have nothing to do with oil pressure.
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    Re: oil pressure
    could have a blockage. if it was me id put a can of seafoam in drive for 30 min then change oil and filter and see how she does afterward. if it still read high i would then hook a diagnostic oil pressure gauge to engine and test the pressure.
    Jan 2014
    98
    Re: oil pressure
    I just changed the oil. I sea foamed the gas but not the engine
    I will do it since I still have a half can of sf left.
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Re: oil pressure
    Not attacking you here but if your piston rings are shot you will lose compression and get a lot of blowby out the exhaust which will also show in a loss of oil pressure.
    deathpulse is offline Cadillac Owners Member
    Nov 2012
    46
    76
    Re: oil pressure
    Mine does this too - I think it is normal. My truck oil needs typically sits a little above the 1/4 marker on the gauge (warm oil) at idle. When accelerating or driving highway etc the needle goes to about 1/2 level in the gauge. This is the same for most cars I think - pressure is much lower at idle RPMs than higher RPMS as the oil pump runs on the engine.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by deathpulse
    I agree its normal as mine has peaked around 60psi under hard acceleration with fresh oil and filter
    Jan 2014
    98
    Re: oil pressure
    But mine goes to 80 during acceleration and idles at 40 during idle. I'm not sure what is going on. I don't feel a loss of pressure. And I put 6 quarts of 5w-30 when I change the oil. Is that too little? I think the manual said 6 quarts but for an 8 cylinder?? Seems not enough. Now when the wife presses on the brakes she hears a creaking sound everytime she presses on the pedal as if something is about to snap or pop. Weird. I've heard that creeking sound when I pumped the brakes several times when the car is off but, now everytime she presses the pedal we can hear the sound clearly. Any thoughts?
    Thanks in advance!
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by drewusmaximus
    But mine goes to 80 during acceleration and idles at 40 during idle. I'm not sure what is going on. I don't feel a loss of pressure. And I put 6 quarts of 5w-30 when I change the oil. Is that too little? I think the manual said 6 quarts but for an 8 cylinder?? Seems not enough. Now when the wife presses on the brakes she hears a creaking sound everytime she presses on the pedal as if something is about to snap or pop. Weird. I've heard that creeking sound when I pumped the brakes several times when the car is off but, now everytime she presses the pedal we can hear the sound clearly. Any thoughts? Thanks in advance!
    Oil sounds normal if you get a warning message in the DIC then worry
    My 03 has made the creaking noise from time to time (more when its cold outside) not sure but I will try and locate the noise as it is annoying
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    Re: oil pressure
    Quote Originally Posted by drewusmaximus View Post
    You won't "feel" a loss of pressure. About the only time you will feel it is if you have a bearing failure and seize the motor. Just make sure your amount of oil is at the proper level on the dip stick and you will be fine. Too little or too much oil can cause their own types of trouble.
    Mar 2011
    speedwell tn,
    11,884
    Drew 6quarts is the right amount of oil for these trucks
  16. Remove Advertisements
