Headers?
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Headers? in Cadillac Escalade Forums; I found another broken exhaust manifold bolt. This makes three. Now I am considering pulling the manifolds, replacing the bolts ...
    Skier-24 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV, White Diamond Pearl
    Jun 2013
    Chesterfield, VA
    56
    278
    Headers?
    I found another broken exhaust manifold bolt. This makes three. Now I am considering pulling the manifolds, replacing the bolts and installing headers. I have searched the forum and all the header threads are old. Anyone have headers on their Escalades? Good or bad experiences? What brand? Long tube or short tube? Louder? Performance gain?
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Re: Headers?
    Check out this article from Hot Rod Magazine. http://www.hotrod.com/techarticles/e...s_small_block/
    I came across this article awhile back while researching the LQ9 engine we have in our trucks. Long tube headers give a pretty decent boost. They did the build up in stages with headers on a stock engine and tune as a starting point. It looks pretty impressive to me.
    CapJack is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Jan 2014
    11
    Re: Headers?
    Are there any problems with changing spark plugs with long tube?
    lonestranger is offline Cadillac Owners Fanatic
    Automobile(s): 05 Escalade ESV Platinum
    Dec 2005
    Bradenton FL
    203
    SmileRe: Headers?
    Quote Originally Posted by CapJack View Post
    Not appreciable difference, PIA ether way, however recommend using the best silicone plug wires you can get to deal with the additional heat, and likelihood of plug wire coming in contact with header tube. Also, get quality coated headers to maximize the life of the headers and minimize the heat situation. I have had both the long and short headers, and in my experience, only the long tube gave any real benefit in performance. The stock manifolds are virtually the same as short tubes if you look at them. They are not nearly as inefficient as the stock manifolds on the older small block motors. Just my experience.
  7. Remove Advertisements
