oil pressure problem
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, oil pressure problem in Cadillac Escalade Forums; Hello, We are from The Netherlands and we have a Escalade EXT 2005. We have new oil, He is clean ...
    Iwan is offline Cadillac Owners Member
    Automobile(s): Escalade EXT ' 06
    Mar 2014
    46
    6
    Hello,
    We have new oil, He is clean from the inside.
    When we driving there is no problem, oil pressure is max.
    But when we use the kick-down and he do 2 gears down, the pressure going to zero, but is coming back in 5 sec.
    What can be the problem ??
    Regards Iwan
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Sounds like the stepper motor in the cluster needs replacing
    michigansilver is offline Cadillac Owners Member
    Automobile(s): 2008 EXT
    Dec 2007
    Southeast Michigan
    36
    Re: oil pressure problem
    When it is idling not moving what is the oil pressure, and does the chimes(bells) come on when you down shift. ?
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    907
    Iwan, welcome to the forum.
    When the gauge drops to zero can you hear any faint ticking from the engine compartment?
    Mar 2014
    46
    6
    Hello,
    When the car is not moving or in P the oil pressure is max ( 60) and when we are going over to drive he is still max.
    Only when we are driving 30mph or more and we using the kick-down ( to accelerate Fast) then will get the oil pressure down in the gauge for a 5 sec and then get to normal.
    We have the car now 5 years and normally we don't us the kick-down but now we see it for the first time.
    We have the car a oil flush but that help not.
    When the oil pressure going to zero the cars driving perfect and we get no message on the gauge.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Iwan
    Hello, When the car is not moving or in P the oil pressure is max ( 60) and when we are going over to drive he is still max. Only when we are driving 30mph or more and we using the kick-down ( to accelerate Fast) then will get the oil pressure down in the gauge for a 5 sec and then get to normal. We have the car now 5 years and normally we don't us the kick-down but now we see it for the first time. We have the car a oil flush but that help not. When the oil pressure going to zero the cars driving perfect and we get no message on the gauge.
    No messages would rule out the sender being bad
    The stepper motors in the cluster were know to fail and give either bad readings or not show anything at all
    Feb 2010
    907
    I agree, I am leaning more towards the stepper motor as well.
    Many members here including myself have replaced the stepper motors in our dash clusters. Fairly easy DIY if you can solder. Also the stepper motors are inexpensive maybe your ebay over there may have them.
    Dec 2007
    Southeast Michigan
    36
    I leaning toward a stepper motor also, as a general rule if the gauge does not return to zero when you turn it off the stepper motor is bad. If it moves from zero to max it's the pressure sensor.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by michigansilver
    True but the stepper motors are cheaper then the sensor and don't take as much time to replace if you know what to do
    Dec 2007
    Southeast Michigan
    36
    Simply stating how to tell the original poster which part is broken. Repair time and cost has nothing to do with.
    Mar 2011
    speedwell tn,
    11,884
    I understand
    Mar 2014
    46
    6
    When the sensor is bad, you get then normally a message on the dash cluster ?? when he goes to zero.
    We get no error on the cluster, only that the gauge go to zero an after 3-5 sec to max.
    So when i read this all, i will do first the stepper motor and when it not going away, we change the sensor.
    Thanks again.
    Feb 2010
    907
    Iwan, I am not 100% positive but I don't think so on the oil pressure sensor.
    From what I have read here over the years I believe that only 1 sensor has been the cause of the gauge showing zero at times. The majority of times is the stepper motors. Here is a tip I learned the hard way, replace all the stepper motors at the same time, although they are fairly easy to replace, why go through the hassles of removing the dash cluster more than once.
    Good luck and let us know how it goes.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jnrsesv
    Iwan, I am not 100% positive but I don't think so on the oil pressure sensor. From what I have read here over the years I believe that only 1 sensor has been the cause of the gauge showing zero at times. The majority of times is the stepper motors. Here is a tip I learned the hard way, replace all the stepper motors at the same time, although they are fairly easy to replace, why go through the hassles of removing the dash cluster more than once. Good luck and let us know how it goes.
    I will put it like this
    I have been suffering the low oil pressure message(its the sender no doubt) but after the engine warms up the message goes away and doesn't return unless my truck has sat for a long period or overnight (then its a but its a hit or miss if I do get the message or not plus my oil pressure gauge doesn't change rapidly like the op stated his does)
    It hasn't done like the op mentioned his did hence why I am leaning more towards the stepper motor and not the sensor(waiting for mine to fail fully before ripping into it)
  17. #15
    Mar 2014
    46
    6
    Is it normally that the oil pressure gauge go to max only when power on is?? and the engine is out.
  18. Remove Advertisements
