2005 Escalade Base with 20" wheels rides poor
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2005 Escalade Base with 20" wheels rides poor in Cadillac Escalade Forums; Hello everyone, I have a 2005 Escalade base that someone has added after market 20 inch wheels with the Cadillac ...
    hermsky is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade Black, 2002 Eldorado ETC White
    Mar 2012
    Saint Louis
    4
    Hello everyone,
    I have a 2005 Escalade base that someone has added after market 20 inch wheels with the Cadillac emblems on them.
    Looks great but rides terrible compared to my 2001 Tahoe with Auto Ride.
    Is there a computer adjustment for tire size other than adjusting the speedometer, that will smooth out the ride?
    I am running 30PSI in the tires to make the ride more acceptable instead of bouncing down the street.
    Has anyone else had problems with 20' tires on an escalade that originally came with 17 " wheels?
    Thanks for your help!
    :yup:
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    That's a side effect of larger rims
    I have stock 17's on my truck and its smooth
    Mar 2012
    Saint Louis
    4
    Re: 2005 Escalade Base with 20" wheels rides poor
    Thanks for your reply!
    Even on this size of a car? WOW.
    I was afraid of that.
    I may have to find a set of factory 17 inch wheels and tires and go back to standard.
    I guess there were some changes to the suspension for the newer escalades coming out with 20" wheels.
    Best regards,
    Scott
    Silent_Assasin's Avatar
    Silent_Assasin is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade EXT - Rip Tide Blue
    Mar 2013
    30
    200
    Quote Originally Posted by the cadillac man View Post
    I highly disagree with this being the case! I ride on 24s all summer long and there is ZERO difference in my 24s to my stock wheels, both ride VERY nice and smooth! .. I would have to say hermsky's problem is beyond the wheels and more in the suspension.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    804
    How many miles on your truck?
    My 05 rode pretty poorly until I started replacing suspension and steering components. I have 90K miles on it now with all the replacement parts coming in the last 1000 miles.
    I've got factory 20s to put on in the spring after I finish the suspension and steering rebuild. between the front and rear the only original pieces are the steering gear and the upper and lower control arms in the front, those are getting swapped out as soon as it warms up. The truck rides almost like a new one now, very smooth compared to before. I suspect the front control arms will finish it out for as close to a new ride as I can manage.
    The upper control arms on mine are pretty shot, likely from living in an area with snow and salt use. All the bushing I can see on the upper arm are cracked pretty badly. Funny thing is the lowers don't look too bad at all, I already have the lower arms so I'll be swapping them out while I've got the front end disassembled.
    20s are going to ride a little more harsh than the 17s, but there is still quite a bit of rubber between you and the road. It shouldn't be that harsh.
    cra_fizzer is offline Cadillac Owners Member
    Automobile(s): 2005 ESV Platinum
    Dec 2013
    52
    7
    I have factory 20s on mine and the ride was very wallowy until I put on new tires with a higher load rating. ie stiffer sidewalls.
    Mar 2013
    30
    200
    unless your riding on tiny little car tires on your 20s there is NO WAY that a 20 inch rims would change the ride on your escalade! I can tell zero difference in the ride from my factory wheels compared to my 24s granted i still have a bigger tire on the 24s the only difference is they rub a tiny tiny bit when i have the wheel turned really sharp! more when in reverse!
    LA Dawg's Avatar
    LA Dawg is offline Cadillac Owners Member
    Automobile(s): 1964 Cadillac DeVille convertible & 2005 Cadillac Escalade
    Nov 2013
    Everett, WA
    32
    I have added custom 20's on my 05 esv w/o a ride problem, believe the tires are 305's with 12 inch foot print, thing corners on rails...took 17's off, too. Just my two cents.....
    SQUIRREL MASTER is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Mar 2014
    The South
    37
    My brother has had the 2004 ESV since 03, and the factory wheels were 17". He added some 20" dubz, with proper alignment and such, and I couldn't tell a difference driving it. My 02 has 26's on it, and it's just as smooth as his with the 20's. My tire size is 305/30vr/26 if I'm not mistaken, but no real problems. To be finicky, I can tell a small difference when traveling over fine, narrow bumps, but other than that, same.
    Quote Originally Posted by hermsky View Post
    Hello everyone,
    Where are you experiencing the discomfort exactly? Highway? Rough terrain or gravel? Over bumps? Or simply, all together?
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    It sounds more like a problem with the autoride system then a problem with the wheels. Are you sure autoride is working? No dash errors? Does the compressor run and are the air shocks inflated?
    Mar 2012
    Saint Louis
    4
    Hi and thanks to all!!
    I finally got under there myself and see the right shock is covered and apparently leaking. Also the pitman Idler appear a bit loose.
    Also see the Torsion Bar adjustments are not even. I wonder if the guy before me tightened them up to stiffen the ride??
    Guess I will see if I can replace the shocks and Pitman Idler to see if that helps.
    Just have to see if I am up to the challenge of changing these myself then get an alignment and set the ride height.
    I really appreciate the comments and help!
    Scott
    Mar 2011
    speedwell tn,
    11,884
    What your describing is called Chevy lean
    Do a google search on it
    Now in order to adjust them you need keys for them
    Leaking shocks is not good
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    i have 26`s and rides like a dream. bet u have bad tires or suspention issues
  16. Remove Advertisements
