Water leaking through blower motor
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Water leaking through blower motor in Cadillac Escalade Forums; Scenario In chicago it was really cold. Blew blower motor resistor. Figured was below -20 and blew, saw service bulletin. ...
    jimmy buffet is offline Cadillac Owners Member
    Automobile(s): 09 sts4 and 04 escalade
    Feb 2010
    38
    22
    Scenario
    In chicago it was really cold. Blew blower motor resistor. Figured was below -20 and blew, saw service bulletin. Replaced and everything good. 1 month later it blew again. Noticed corrosion on new plug. Not wet though. Left cover down and nothing for 4 days. Then car wash and water coming through blower motor. So it soaked into foam and shorting resistor.
    Problem.
    Why or where is water coming from. Anyone know how duct is run, dont see anything wrong. Possibly a plug thats clogged.
    THANKS FOR ADVICE IN
    Escalade 2004
    zeeter21 is offline Cadillac Owners Member
    Automobile(s): 2005 cadillac escalade esv platinum
    Jan 2014
    harrisburg south dakota
    14
    I believe a heater core is bad or needs flushing ASAP. Dont hesitate. Fix
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Sounds like your A/C condensate drain is plugged. Not sure exactly where it is on your truck though.
    A failed heater core will cause coolant to leak onto the floor, not water. And a heater core in need of a flush is clogged, not leaking.
    65kaiser is offline Cadillac Owners Member
    Mar 2013
    Crystal Beach Florida
    59
    47
    Re: Water leaking through blower motor
    I had the same problem. Under the hood up by the windshield directly above the blower motor is a black cover about 4" by 10" Remove the cover, You can look down and see the blower motor. the seal on that cover is probably shot. I just resealed with a bead of black silicone and replaced the cover. problem solved.
  7. Remove Advertisements
