RPMs Jumping mainly in 4th gear
Results 1 to 14 of 14
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, RPMs Jumping mainly in 4th gear in Cadillac Escalade Forums; About 10 months ago, I had my Transmission rebuilt. 2005 Escalade, 5.3L V8 2WD, 170k. About a month ago , ...
    Lepper is offline Cadillac Owners Member
    Automobile(s): 05 Escalade
    Mar 2014
    Savannah
    22
    About 10 months ago, I had my Transmission rebuilt. 2005 Escalade, 5.3L V8 2WD, 170k. About a month ago , I was driving
    and had to get the car towed because of hole in the transmission coolant line. The same guy who did the transmission rebuilding fixed the hole at no cost. Ever since I got it back, the RPMs have been jumping. I checked fluid and its good. It happens right when I get to 4th gear at about 50 MPH and if I stop accelerating , it obviously stops, but 5 seconds into reaccelerating it starts to bounce between 1500 and 2000 RPMs. It doesn't really bounce in the lower gears but will do some hard shifting if I accelerate too hard out of sharp turns. Oil change was 1500 miles ago with Mobil 1 High Millage Fully Synthetic. From the reading that I have been doing these forums it could , it seems to be it could be a TCC problem or Air filter issue. I am no expert, but I can do the essentials like fluid changing and top offs. I also have a theory, because I topped off my fluid recently with
    DEX 3, less then half a quarts worth, and I am thinking maybe the mechanic filled it up with DEX 6 and it is diluted possibly or some gunk is built up. I don't know, I need some answers though as it is the only vehicle in the household. Thank you
    Mar 2014
    Savannah
    22
    Re: RPMs Jumping mainly in 4th gear
    No one has a solution? I'm thinking about doing a trans fluid change to see if it makes a difference.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Lepper
    Mine did almost like this and a fluid change fixed it
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    i did a fluid change and corvette servo. dont know which one fixed it but i sure liked the corvette servo. its very easy to install
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bigirb2002
    It was likely the servo that was bad
    Mar 2014
    Savannah
    22
    Today I was driving and the check engine light came on finally. Engine isn't jumping as bad, but like I said the light is now on.
    Mar 2011
    speedwell tn,
    11,884
    If you have a code reader and can get the codes I can help more
    Mar 2014
    Savannah
    22
    Quote Originally Posted by the cadillac man View Post
    dont have a reader :/
    I will have to find a friend with one or go to a GM place.
    Mar 2011
    speedwell tn,
    11,884
    dont have a reader :/ I will have to find a friend with one or go to a GM place.
    I think any parts place can do it and they are free so try there first before going to a dealer
    Mar 2014
    Savannah
    22
    I filled it up with 1.25 quarts of DEX 6 and it fixed the issue strangely enough. One of my hoses are dripping a very small amount of trans fluid, which might over time make have to do top offs more often. I am about to get new brakes and will get new hoses when I do. I think that the mechanic didn't top off the fluid when he patched the hole in the line. I still get an occasational rpm jump but way more mid and very rarely it has been doing it. Engine light is still on.
    Mar 2011
    speedwell tn,
    11,884
    I work the tranny through the gears before I check the fluid level in the tranny starting at 1 and working back to park
    Mar 2014
    Savannah
    22
    Did that too . Especially right afterwards and drove on each gear for a few minutes each. Stay tuned folks haha.
    Mar 2014
    Savannah
    22
    Engine check light has turned off and transmissions seems back to normal strangely enough. Mechanic didn't top off transmission. I just have to get my brakes done now.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Could have been a intermittent code still is best to pull the code to be safe from possible problems later on
  17. Remove Advertisements
