Can anyone recommend a strong glue for the grill emblem?
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Can anyone recommend a strong glue for the grill emblem? in Cadillac Escalade Forums; I just replaced the stock grill to an aftermarket and I need to change the emblem from the grill I ...
    cpmet200's Avatar
    cpmet200 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac Escalade ESV
    Jul 2011
    80
    QuestionCan anyone recommend a strong glue for the grill emblem?
    I just replaced the stock grill to an aftermarket and I need to change the emblem from the grill I took off to the new one. (Already took emblem off using a heated gun). Can anyone recommend a really good strong glue to use that I can get from like AutoZone, Walmart, etc ? Thanks!
    michigansilver is offline Cadillac Owners Member
    Automobile(s): 2008 EXT
    Dec 2007
    Southeast Michigan
    36
    Re: Can anyone recommend a strong glue for the grill emblem?
    JB Weld but it takes hours to cure and you will never get it off again or maybe gorilla glue. Home Depot
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Either 3M double sided trim tape or 3M plastic emblem and trim adhesive
    vicb is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade, 2002 SL 500 Silver Arrow
    Jan 2012
    Plano, Texas
    49
    141
    I have used that 3m ahhesive glue and it works fine. Attached a emblem a few years ago and still holding strong.
    Sep 2010
    East Boston MA.
    29
    26,325
    I'd bet money it was originally attached with the double sided tape. Either 3M product will work fine. Construction adhesive and arts and crafts glue isn't quite right for this application.
    godsdiablo's Avatar
    godsdiablo is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac Escalade
    May 2008
    New York
    1,177
    3m won't hold up if the surfaces aren't cleaned correctly. you could try stripping all the old 3m and putting new (50/50 shot) or try using spray adhesive but be careful of over spray , spray let it get tacky and it'll be fine
    zeeter21 is offline Cadillac Owners Member
    Automobile(s): 2005 cadillac escalade esv platinum
    Jan 2014
    harrisburg south dakota
    14
    Only use 3M . Its the best no questions.
  10. Remove Advertisements
