Weird issue!!!Dashboard lights flickered/reset while driving!!!
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Weird issue!!!Dashboard lights flickered/reset while driving!!! in Cadillac Escalade Forums; So this strange has happened about 2-3 times in past month. The first time I flashed my high highbeams at ...
    sosatyme72 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Escalade ESV
    Mar 2013
    44
    189
    So this strange has happened about 2-3 times in past month. The first time I flashed my high highbeams at a car in front of
    me and my whole dash flickered on and off kind of when I first turn on the truck all the needles went down came back up, the radio turned off/on, headlights flickered all this while I was on the highway going about 40-50mph then it went normal but I tried flickering my high beams again and couldnt get it to re occur.
    Today again coming out the gas station it was already dark out pulling out all of a sudden they all reset again with no headlights on, no dashboard lights, no radio but Im still driving while its going on then like a few seconds eveything came back up again. I pulled over to start to turn off car and turn it on again, put my high beams on to see if anything but no luck.....
    Has anyone ever expeirence something like this ? or what can it be??
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Sounds like a bad ground
    Check the battery cables to see if they are loose(if loose tighten them)
    topmillwright is offline Cadillac Owners Member
    Automobile(s): escalade
    Oct 2013
    50
    10
    Maybe try not flashing your high beams at people.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by topmillwright
    If someone had they're high beams on wouldn't you flash your to let them know they left they're on??!?
    That's what the flash to pass feature is used for mostly at night
    Oct 2013
    50
    10
    The poster said flashed them at a "car in front of me" which makes me think they just wanted them out of their way.
    Mar 2011
    speedwell tn,
    11,884
    I also had to use the flash to pass for that too so my theory still stands that its a loose ground somewhere in the truck
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    Re: Weird issue!!!Dashboard lights flickered/reset while driving!!!
    i agree with the caddillac man an def bad ground . check all grounds on engine harness. also remember theres a ground thats under all the engine plastic near the rear of the engine that can cause this to. but easiest first maake sure battery terminals are tight. cant tell u how many times mine has came loose causing all sorts of head ache
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bigirb2002
    I know how you feel there sheesh
    Mine got loose once and caused the dash to go dead even though the headlights and interior lights worked it also wouldn't let the truck start
    Mar 2013
    44
    189
    thanks alot for your input i'll look into it..
    Quote Originally Posted by the cadillac man View Post
    79wolf is offline Cadillac Owners Member
    Automobile(s): 2005 ESV Platinum
    Feb 2014
    Normal, IL
    37
    3
    I've had similar issues and I have a theory that I would like others input on:
    Mine has done this quite a few times and from what I can tell there is a heavy electrical draw on the system at the time (heated seats, lights, stereo, and then raise or lower a window; most recently was when the traction control kicked on while taking off from a dead stop on snow), but not every time a draw occurs. I've been told the regulators in these alternators are weak and I'm wondering if mine is going out again, causing the voltage to drop and all electrical devices suffer or shut off. I know it's the same as the loose ground, but I've already gone that route with no luck. Anyone have any thoughts?
    Mar 2011
    speedwell tn,
    11,884
    Its possible but still rarely heard of
  14. Remove Advertisements
