Regulator cable snapped off
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Regulator cable snapped off in Cadillac Escalade Forums; So here is the situation. My 14 year old daughter was about to get out of the rear passenger door. ...
    spirit man's Avatar
    spirit man is offline Cadillac Owners Member
    Feb 2013
    44
    QuestionRegulator cable snapped off
    So here is the situation. My 14 year old daughter was about to get out of the rear passenger door. She said the child lock was on. I rolled the window all the way down so she could open the door from outside. When I tried to roll it back up, it sounded like it wanted to try, but it wouldn't move. I tried the switch on the drivers side and the rear passenger door.
    I took the door panel off today and I saw the pulley cable had snapped off. Does this mean I only have to replace the window regulator? 04 Base BTW
    Also, the window is "stuck" in a position in which I cannot simply unbolt the glass from the track.
    wesyder's Avatar
    wesyder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    Yes jus the regulator if you can find it separate, your gonna have to force the window carefully to get it to a position to unbolt it
    spirit man's Avatar
    Feb 2013
    44
    Re: Regulator cable snapped off
    Quote Originally Posted by wesyder View Post
    thanks for the advice. I wish I could use Amazon but since I need it now I can't wait around to have it shipped.
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    What i've done before is pushed the window back into full up position, and then use a block of wood, cut to the right length, to pin the the window up. This allows you to use the vehicle while you are waiting for a new regulator to show up. Regulators are real easy to find in junk yards, if you happen to have a local one, will be much cheaper then the dealer.
    spirit man's Avatar
    Feb 2013
    44
    Quote Originally Posted by z0lt3c View Post
    Do I need to cut the rest of the cable(s)? This sucker will not move. LOL
    z0lt3c's Avatar
    Nov 2013
    Central NJ
    171
    If the cable is bound, yes, cut it, you need to get the window to move manually again.
    spirit man's Avatar
    Feb 2013
    44
    Thumbs upRe: Regulator cable snapped off
    Thanks guys...I didn't wait. I went to Autozone and picked up the regulator with the motor. I had a coupon for $15 off so that helped. Looks like my model was the regulator and motor as one whole assembly. Install went super smooth while I was watching the NFC Championship game.
  10. Remove Advertisements
