Changed my plugs last night!
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Changed my plugs last night! in Cadillac Escalade Forums; I've had a slight stumble/miss when in gear and stopped. Slightly annoying, but no CEL's. So I grabbed some NGK ...
    Tylus's Avatar
    Tylus is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Dec 2013
    Pearl Harbor
    34
    74
    I've had a slight stumble/miss when in gear and stopped. Slightly annoying, but no CEL's. So I grabbed some NGK plugs and went at her!
    Stupid rubber boots have been sealed on there, and I'm sure those were the factory plugs @ 66,000 miles. Took me over 2hrs to do the swap, man that was a bear to find access to #7 and #8 cylinders. I thought my Ford Modular motors were bad for access...wow
    Anyways, buttery smooth idle now while in gear and stopped. Hopefully see a little MPG gain as well, but I doubt it
    Drivers Side
    Passenger Side
    btw, just wanted to throw out there that there is no way in hell those are 100,000 mile plugs. I checked their gaps and it was on average 0.080. Those are platinum tip plugs and they are supposed to be 0.060 gap from factory. I put the new plugs in with a gap of 0.040 per the TSB since my new plugs were iridium tips.
    I've never believed that 100,000 mile crap that Ford/Dodge/GM have gone to, and this illustrates it perfectly to me. I typically do a 2yr or 30,000 mile swap personally. Plugs are cheap, I think I paid $32 for a set of 8 "middle of the road" plugs for the 6.0.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I changed mine at 120,000 and I agree it did make a difference in the idle and power of the engine
    Johnny fox is offline Cadillac Owners Member
    Automobile(s): 2003 escalade esv
    Oct 2014
    38
    49
    I changed mine here recently my budy was a mechanic at a gm dealership and said those are the original plugs they have a little over a 120,000 on them don't get me wrong they were at .060 thousandth's with the tip burnt completely off and the new ones are .040 thousandth's it ran good still I just wanted to check everything someone else neglected and my milage seemd low that was my last resort I can't believe it still ran on those plugs I never believed the 100,000 mile plugs either but I'm a believer now but I'm sure where you live and the type of fuel you get all makes a difference
    Oct 2014
    38
    49
    And I wish I can remember what he was telling me about ac Delco but it was something like there's actually 2 ac delcos the ones you buy at advance, auto zone or wherever aren't the real deal the tips and the white part around it are made from a different type of material either way the real deal delcos are way more expensive than anything you'll buy at a part store
    SugsPa is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade, 2008 STS-V
    Jun 2013
    Paducah, KY
    61
    40
    Re: Changed my plugs last night!
    I have 137K on my 06 on the original plugs. I know they've never been changed because I bought it new in June 06. I've been thinking about changing them but it still runs great. I have a set AC/Delco that I bought at Advance Auto, but now Johnny fox got me wondering if they are good set of plugs or a cheap imitation.
    SugsPa
    lonestranger is offline Cadillac Owners Fanatic
    Automobile(s): 05 Escalade ESV Platinum
    Dec 2005
    Bradenton FL
    203
    CoolRe: Changed my plugs last night!
    Quote Originally Posted by Tylus View Post
    Drivers Side
    Passenger Side
    It is better to attack this job with a new set of plug wires on hand. Both due to excellent chance of damaging one or more plug boots in trying to get them off, as well as if the plug wires are several years old, you should change them anyway. Plug wires wear out with time and may be the actual reason for an engine stumble! Also, don't just shop for the cheapest plug wires you can find. They live in a very hostile environment! Get the best you can find. Just my two cents worth!
    Mar 2011
    speedwell tn,
    11,884
    ^ I agree
    I didn't replace the wires when I did the plugs last time(starting to regret that decision) going to do both next time(when it comes up)
    NYS
    NYS is offline Cadillac Owners Member
    Jul 2012
    36
    Also, keep in mind that the original 41-985 spark plugs were Iridium, not Platinum.
    Iridium tips are tapered to be thinner. Some people see this gradual tapering at the very tip and think this is the result of the tip being "burned off", but this isn't the case at all. These aren't our father's spark plug tips. Our father's spark plug tips couldn't be tapered to such a thin point because the arc energy would indeed burn it off.
    However, it is to our advantage to have as tapered and as thin of a tip as possible, only we couldn't until cost effective Iridium deposition techniques were developed for spark plugs. Iridium's properties enabled spark plug tips to adopt a more ideal shape than older plugs of the past, or cheaper plugs (without Iridium) of today. The use of Iridium isn't just about making a longer lasting plug... that is just a corollary benefit. The advantage of Iridium is that it's properties enable a more ideal spark plug tip shape... tapered thinner and more pointed at the end.
    Here is a table that compares some physical characteristics and performance parameters between tip coatings on spark plugs:
    Here is a Family Handyman image that illustrates the difference between tip shapes from a conventional versus iridium tipped plug:
    Here is an NGK of Japan image close up of the tapering of the NGK (who manufacturers the ACDelco Iridium plugs) Iridium tip:
  11. Remove Advertisements
