06 Escalade sways side to side at highway speeds (60mph+)
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 06 Escalade sways side to side at highway speeds (60mph+) in Cadillac Escalade Forums; Hey all, My mother owns a 2006 Escalade with 70k miles. She has always complained of a soft, bouncy ride ...
    Hmbre97 is offline Cadillac Owners Member
    Automobile(s): NONE
    Jun 2011
    Austin, Texas
    1
    Hey all,
    My mother owns a 2006 Escalade with 70k miles. She has always complained of a soft, bouncy ride since buying it a couple of years ago (at 62k miles). I finally got a chance to spend a couple of days behind the wheel while on a road trip this past week and man, that thing rides like crap. On the highway, any bumps would cause it to start oscillating side to side. I have driven cars with bad shocks that tended to get bouncy but I didn't feel any bounce from front to rear, only side to side. It was bad enough that after a couple of hours in the back seat, my wife got pretty car sick which never happens.
    Is this normal for the air suspension in these trucks or could the shocks be bad? I think they're holding air as I heard the compressor a few times but it would only run a short while and cut back off.
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    Re: 06 Escalade sways side to side at highway speeds (60mph+)
    Sounds like bad front electronic shocks, they are mostly responsible for the reduction of body roll. Or it could be a failure of the suspension system resulting in a shutdown of the dampening, but that usually results in a service error message on the dash board. If the front shocks are blow the rear shocks most likely are not far behind/ 80K miles is about the life span for the OEM parts. It's about $1000 to replace the 4 shocks w/ OEM equivalents... You can also look into upgrading the front and rear sway bars.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I second the front shocks and away bars as even in passive mode it shouldn't be that bad
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    My 05 has a bit of a shimmy at highway speeds. I think with the weight of these vehicles (almost 2 Corvettes) that they are very hard on their suspension components which to me see a bit under designed for the weight of these trucks.
    Does the whole truck feel like it is oscillating back and forth or does it feel more like the rear end? In the back there is a panhard bar in line with the rear axle that controls the side to side action as the suspension is compressed and rebounds. I wonder if maybe you have worn bushings in the panhard.
    I've been under my Escalade and at 90K miles the suspension looks like it needs some work. Both in front and back I see cracks in the bushings and some tearing. When it warms up in the spring I plan on rebuilding the front and back suspension, replacing all related items. I'm hoping it cures my problem.
    I replaced the shocks on my 05 at 85K miles thinking it was the problem but it made no difference to the ride quality. Surprisingly these expensive shocks seem to be pretty well made, not like the previous generation of ride control shocks that seemed to be shot just after 60K miles. My friend has 170K on her Denali with the same suspension and her shocks are still holding up, no leaks, seem to be just fine. In fact after I rebuild the suspension in the spring I plan to put those 85K mile shocks back on.
    I had an 02 Trailblazer that I rebuilt the suspension on @ 90K miles and it made a crappy ride like a new truck again in the front, so good in the front that I started noticing how the back end felt a little sloppy. Ended up trading it for the Escalade before getting around to rebuilding the back.
  7. Remove Advertisements
