Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Getting "Check Engine Oil" Message...
    sosatyme72 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Escalade ESV
    Mar 2013
    44
    189
    I recently changed my oil with synthetic and I have about another 2500 miles to go to change out again...every 5k i was told to change. I never reset any type of oil settings in car. Could this be why Im getting this message? I havent checked the oil
    since its been somewhat recent but what you guys think?? Should I reset the oil settings?
    dbbspider is offline Cadillac Owners Member
    Automobile(s): 06 escalade ext
    Dec 2013
    Socal
    39
    Re: Getting "Check Engine Oil" Message...
    I would reset the OLI when u change ur oil
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Check engine oil message is NOT a change engine oil message
    I would check it ASAP to make sure it ain't low if its not low then a sensor is bad
  5. #4
    Mar 2013
    44
    189
    I just checked the oil and the dipstick has 5 lil holes on it, oil level goes up to the 3rd hole. Do I need more oil? It should go to at least the 5th hole on dipstick?? sorry for the stupid question but not sure..
    Quote Originally Posted by the cadillac man View Post
  6. #5
    Dec 2013
    24
    That isn't too bad, maybe a tad low. Are you checking oil on level ground with engine off? There should be a hash marked area to show oil is low. Maybe half a quart would take it to full based on what you are saying. But like posted earlier, ck oil does not mean time to change oil, you'll get message that tells you time to change oil. You should reset your oil counter with each oil change. GM has a nice algorithm to calculate when you should change your oil, it isn't simply a mile calculator, it takes into account how you drive, temps, etc when it decides oil needs to be changed.
  7. #6
    Mar 2013
    44
    189
    yeah engine is cold and pretty sure its level, and i see no hash mark just the holes... if the engine oil is low wonder where the oil is going to , I have no leaks on ground. Only thing that I now of I still have to change mt cat. converter which is bad but I feel no difference in engine or ride.
    Quote Originally Posted by JihadSmaidy View Post
  8. #7
    Dec 2013
    24
    If you are seeing a drop in oil and no spots on ground, probably leaking to engine and you are burning the oil. You can check your exhaust, if leaking to engine will see a slight bluish tint to exhaust. But if you are talking about half a quart in 2500 miles, not huge leak if an older car (might be hard to detect). But should look into it, will only get worse. Could be leaking to coolant system. That is easy to check, coolant will appear and feel oily. What year is your car? I can tell you when I change oil, I sometimes check oil level prior and it has always shown full.
  9. #8
    Mar 2011
    speedwell tn,
    11,884
    One thing is miles my truck does use some oil between changes but its like half a quart which I have been told is normal for high mileage engines (truck has 170,000 miles)
  10. #9
    Mar 2013
    44
    189
    ok its a 2003, but i was reading around and someone has issue similar when they switched over to synthetic its was getting low then theyswitched back to regular oil and it was fine. This was my first time putting synthetic oil in my truck, i just bought it in March , has 117k now.
  11. #10
    Dec 2013
    24
    So you don't have that many miles on it. I have only used synthetic in my cadillac. Doesn't seem like switching from regular to synthetic would cause to start leaking around gaskets and what not. Unless there is a break in period? Maybe after so long the seals and gaskets readjust? I have had other cars I switched over to synthetic that pervious owner used regular and didn't experience oil loss (or at least didn't notice one). Like last post, when you start putting a lot of miles on a car, losing some oil to the engine normal. But he is saying half a quart over an oil change, you are about double that with not that many miles on it. Anyone heard of switching to synthetic cause small oil leak?
  12. #11
    Mar 2011
    speedwell tn,
    11,884
    I seen it on other forums but it is still rare
  13. #12
    Mar 2013
    44
    189
    ok i'll just keep my eye on it...but does anyone know about the dipstick, mine has the 5 lil holes, is it topped off once it resaches the 5th hole?
  14. #13
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sosatyme72
    Mine is the same way
    These trucks hold 6quarts of oil when full
    Haven't had my oil changed yet so I can't comment as to where its at on the dipstick
  15. #14
    Dec 2013
    24
    Yes, topped off when at top of 5th hole. I am pretty sure each hole is like 1/4 of a quart so add half a quart and see if that fills her up.
  16. #15
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    The dipstick on mine has hash marks and a solid line at the top of them. That's where I fill it to.
  • You may not post replies
