Getting "Check Engine Oil" Message... - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Getting "Check Engine Oil" Message... in Cadillac Escalade Forums; ok so i added half a qt yesterday and topped it off to the 5th hole on the dipstick. Ran ...
  1. #16
    sosatyme72 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Escalade ESV
    Mar 2013
    44
    189
    Re: Getting "Check Engine Oil" Message...
    ok so i added half a qt yesterday and topped it off to the 5th hole on the dipstick. Ran it a few a times ,later that night I still got the Check engine Oil message.. I went into the oil settings and saw that engine oil life was at 3%, i reset to 100% ..hope that does the trick....not sure why it would
    still keep showing me that message if its full...
  2. #17
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Could be the sensor bad
  3. #18
    JihadSmaidy's Avatar
    JihadSmaidy is offline Cadillac Owners Member
    Dec 2013
    24
    It could be a bad sensor, another thing I noticed when about a year ago I had issue with a check engine light, once the error was detected and light came on, I could not get it to go away unless I had it reset. Sometimes auto zone would hook up their machine and do it for free or I would pull fuses to reset the pcm I believe it was. Maybe check oil light is same way, once it is triggered you need to have it reset.
  5. #19
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,808
    No reset on the oil level sensor, I'm going to go with intermittent failure
  6. Remove Advertisements
