Cleaned the Headlights interior - Wow!
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Cleaned the Headlights interior - Wow! in Cadillac Escalade Forums; What was GM thinking with that design? I've never seen such a bassackward setup! Luckily the Denatured Alcohol worked for ...
    Tylus's Avatar
    Tylus is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Dec 2013
    Pearl Harbor
    34
    74
    What was GM thinking with that design? I've never seen such a bassackward setup! Luckily the Denatured Alcohol worked for the most part. It seems that some of the silver/chrome came loose...but not a lot.
    Think I'm going to do the bake trick this holiday. Paint the suckers black interior. Also going to pick up a Headlight Cleaning kit. There is a lot of road grime/haze on the exterior of the lenses.
    We'll see how they work tonight in the dark. Had to use a hairdryer to speed up the drying process. Stupid clouds kept hiding the sun and I wasn't in the mood to wait. Hairdryer worked really well actually. Made sure to use the hole where the HID bulb goes since it's a metal part. Was worried the hairdryer would melt the plastic.
    FYI: If you've never seen the abovementioned "baking headlights" mod, here is a link to when I did my F-250
    http://www.ford-trucks.com/forums/10...arley-mod.html
    pickandchoose is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Nov 2013
    Florida
    10
    Re: Cleaned the Headlights interior - Wow!
    Rubbing alcohol would work too right?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I used plain tap water to clean the housings out
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Most any alcohol will work. Somewhere around 1/5 alchohol, 4/5 distilled water. Water must be distilled or you'll have spots.
    Tylus's Avatar
    Dec 2013
    Pearl Harbor
    34
    74
    I had a gallon jug of di water I used.
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    what did they look like before?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by MoistCabbage
    I didn't have spots after I cleaned mine and I used only water
    Sep 2010
    East Boston MA.
    29
    26,323
    Try with some hard water .
    Mar 2011
    speedwell tn,
    11,884
    Ahh I see hard water stains uncool
    Tylus's Avatar
    Dec 2013
    Pearl Harbor
    34
    74
    Quote Originally Posted by z0lt3c View Post
    I don't have a good pic of the heads from before...here is the night I bought it. mostly haze over the low beams
    guess I bumped the settings while assembling. need to re-aim tomorrow. light output is way up though. happy with this "mod"...'er, would that be preventative maintenance?
    Sep 2010
    East Boston MA.
    29
    26,323
    Maintenance, but not preventative.
    Now you need to sand/polish the outside. The tops look a little yellow.
    Tylus's Avatar
    Dec 2013
    Pearl Harbor
    34
    74
    yep, I have a can of polishing compound somewhere in the garage. can't find it of course. going to grab a can at Walmart tomorrow rather than destroy the garage looking for it. been 2-3 yrs since I used it, so might have dried out anyways
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Tylus
    Let me know what kind you get as my passenger side needs polishing due to being in the sun
  16. Remove Advertisements
