Driver seat & both front heated seats
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Driver seat & both front heated seats in Cadillac Escalade Forums; I have an 05 Escalade & the driver's power seat is not working & neither are the seat heaters for ...
    Maximln is offline Cadillac Owners Enthusiast
    Automobile(s): 08 STS V8 AWD, 1SG, Platinum Edition
    Jan 2003
    Fresno, CA
    662
    I have an 05 Escalade & the driver's power seat is not working & neither are the seat heaters for both front seats. The power seat on the passenger side does work. When you move any of the driver's power seat buttons, none of them work. Also, when you push the memory buttons, the seat doesn't move either. And nothing happens when you push any of the driver or passenger heated seat buttons. This happened a few weeks ago & then randomly, everything would work fine again but now nothing has worked for about a week. When I look at all the fuses & circuit breakers, I cannot find anything specific to the driver front seat or the front seat heaters. I found a couple things for the rear seat heaters but nothing for the front. Does anyone have any ideas?
    Thanks,
    Max
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    906
    Re: Driver seat & both front heated seats
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    It sounds like the seat module on the drivers seat has failed
    Feb 2010
    906
    That's what one would think, but you are better off trying my free fix first! Follow the link above.
    Jan 2003
    Fresno, CA
    662
    jnrsesv,
    THANK YOU SO MUCH!!!! That was exactly the problem!! I removed the cover & disconnected & reconnected the wiring harness & now the seat & both seat heaters work again!! You are wonderful!!
    Max
    Feb 2010
    906
    You are welcome. From my experience you need to get at least one small zip tie to secure the 2 connectors together.
    Jan 2003
    Fresno, CA
    662
    You mean tie the zip tie around the connector & pull it tight?
    Thanks again,
    Max
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Maximln
    You mean tie the zip tie around the connector & pull it tight? Thanks again, Max
    You are correct
    Jan 2003
    Fresno, CA
    662
    Thanks again! Will do it!
    Max
  12. Remove Advertisements
