whirring noise from front of the car at 10 to 25 mph! Help Please!!
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, whirring noise from front of the car at 10 to 25 mph! Help Please!! in Cadillac Escalade Forums; ...
    wantvegas is offline Cadillac Owners Member
    Automobile(s): 04 escalade platinum
    Mar 2013
    Rocklin, CA
    28
    6
    Unhappywhirring noise from front of the car at 10 to 25 mph! Help Please!!
    I have a 2004 Cadillac Escalade AWD. About a month ago a whirring noise from front of the car started happing. (Sounds like a jet engine turning off)
    I cannot for the life of me find this noise. Any help please!
    Here’s all the info:
    I have replaced the front rotors, brake pads, driver side wheel barring, tie rods, drives side control arm bushing, changed the differential fluid. I have also had the tires balanced and rotated and a new alignment. They are new tires with less than 3k miles on them too.
    I cannot figure out what it could be. I only hear it from 10 to 25 mph. I’m not 100% sure, but I think it goes away when I apply the gas.(I say I’m not sure because the engine noise might just be masking it) Doesn’t matter if I’m turning or going straight. No change in how the car performs either.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Has the tranny had any service lately(also has the fluid level been checked)
    Mar 2013
    Rocklin, CA
    28
    6
    Re: whirring noise from front of the car at 10 to 25 mph! Help Please!!
    Tranny has not been serviced lately, I did check the level. Level is good, fluid is still pretty red, no smell of burning.
    Mar 2011
    speedwell tn,
    11,884
    Only thing I can think of is a bearing
    Mar 2013
    Rocklin, CA
    28
    6
    Same here, but I already replaced the drivers side, and the passengers side I have checked over a few times.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wantvegas
    Could possibly be the passenger bearing as I had to replace one on my previous car and the other was not too far behind
    Its best to replace both to be sure and safe
    One way to tell if the noise goes away when you make a right hand turn then it is the wheel bearing
    If not then you have another bearing somewhere else going bad
    dahubby98's Avatar
    dahubby98 is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Sep 2013
    Missouri
    61
    Could also be the front diff. had the same problem while mine was under warranty. Cadiilac replaced the front diff. Not sure how to diagno siit but could be something t consider...
    wilbanks51 is offline Cadillac Owners Member
    Automobile(s): 2006 escalade
    May 2011
    65
    45
    I believe my front diff. is making noise also. Bought new, but has 140,000 on it now. Probably not covered under warranty. Wondering what this would cost?
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    driver side differential carrier bearing more likely. put some moly in the front diff it will help tremendously. best thing u can do is get diff rebuilt and after breakin put moly in the front diff.
  12. Remove Advertisements
