05 Escalade Rear Heat Problems
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05 Escalade Rear Heat Problems in Cadillac Escalade Forums; Does any know why a person doesn't get rear heat and blend door is stuck in the cold position. I ...
    sajjenkins is offline Cadillac Owners Member
    Automobile(s): CTS, Escalade
    Dec 2013
    3
    I put a new actuator in but didn't help. I did pull out the ECC fuse and it will re-calibrate both actuators but still stuck in the cold position.
    Do you think it's a Heat Control Resistor or someone mentioned about taking apart the rear controls and see if that's the cause.
    Any help would be greatly appreciated.
    Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Check out the rear air service thread I made under the FAQ section at the top of the forum page
    Sounds like your having the same issue I had I ended up replaceing both the actitutior and the brain(control) box in the back before it would go off cold
    Mine did around this time of year and ended up killing the battery so just a FYI pull the fuse so it don't run your battery down before you replace the module
    Also DON'T replace it with the same number module as gm changed part numbers on the module
    Dec 2013
    3
    Re: 05 Escalade Rear Heat Problems
    Have you ever heard of the Secondary(Rear) Controls being the problem for the Hot/Cold?
    Also do you have the new GM part number for the Revised Module?
    Thanks
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sajjenkins
    Have you ever heard of the Secondary(Rear) Controls being the problem for the Hot/Cold? Also do you have the new GM part number for the Revised Module? Thanks
    If your referring to the control panels that has only been reported with the front hvac unit
    Any gm dealer can get the number(it's not on my module and I don't think it was on the box or invoice I have though I could be wrong)
    Dec 2013
    3
    Nope, he said the rear controls but also if they were upper ones which mine are on behind the floor console. I didn't get a chance to take my controls out last night but looks like they are a push button rather than the dial like on the overhead consoles.
    Ok, I will check with GM for the revised number.
    So a person should probably steer towards the Heat Control resistor Module?
    Mar 2011
    speedwell tn,
    11,884
    Nope, he said the rear controls but also if they were upper ones which mine are on behind the floor console. I didn't get a chance to take my controls out last night but looks like they are a push button rather than the dial like on the overhead consoles. Ok, I will check with GM for the revised number. So a person should probably steer towards the Heat Control resistor Module?
    I know I was refering that the front hvac system has been more reported to have issue with the control panel vs the rear on front or rear controls
  9. Remove Advertisements
