2002 Escalade EXT mechanical issue
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2002 Escalade EXT mechanical issue in Cadillac Escalade Forums; When I first turn on the car within 5 minutes i hear some Mechanical noise it goes on for about ...
    pellegrino is offline Cadillac Owners Member
    Nov 2013
    33
    When I first turn on the car within 5 minutes i hear some Mechanical noise it goes on for about a minute then shuts off. No clue what It could be anyone ever have this issue and could tell me how to get it fixed definitely do not think thats supposed to happen. Thanks!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Is the truck moving when it does this?
    Is there any messages shown on the information center?
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Re: 2002 Escalade EXT mechanical issue
    Air compressor for shock absorbers?
    Nov 2013
    33
    It starts when i start moving
    It does sound like a compressor just never usto hearing that so its new to me just wanted to make sure it was supposed to be doing that and not that something was malfunctioning
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by pellegrino
    It starts when i start moving ---------- It does sound like a compressor just never usto hearing that so its new to me just wanted to make sure it was supposed to be doing that and not that something was malfunctioning
    Easy way to tell
    Turn the key to run(engine and hvac units off) and you should be able to hear the air shock compressor kick on
    I know I can hear mine with the window down sometimes with the engine running but not every time
    Tylus's Avatar
    Tylus is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Dec 2013
    Pearl Harbor
    34
    74
    I had the same thought with my new to me 'lade last week. But then I was crawling underneath and noticed the ride hieght sensors and compressor. Found a few threads on this site about the setup...not worried anymore. luckily my shocks/compressor seem to be in good shape and I only hear the noise every blue moon
    Nov 2013
    33
    The original owner was telling me that the sound is the traction control and it does it everytime I turn the car on for the first time. Also now i have noticed it has been doing it more often even when I am driving. Anyone have this problem before? I want to know how to fix it im pretty sure it shouldnt be doing that. Also he said he disconnected the air shocks and put regular shocks in would that have anything to do with it? Thanks again
    Tylus's Avatar
    Dec 2013
    Pearl Harbor
    34
    74
    Traction control doesn't make noises. Ever! TC is a strategy the PCM uses to prevent/stop wheelspin by using brakes, ride height, etc
    It does sound like your rear air compressor is pressurizing the rear air lines for those missing shocks. Crawl underneath and see if you have 2 pressure lines that aren't connected to anything. at the very least, those lines should be capped/plugged. If the lines are missing, check the air pump itself to see if the connections are capped/plugged
    there is apparently a conversion kit to go from air-ride to traditional shocks for our cars. hopefully the prior owner did that. do you have any messages on the messenge center?
    dahubby98's Avatar
    dahubby98 is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Sep 2013
    Missouri
    61
    You can disconnect the air compressor by removing the relay that is attached to the fuse box. it shoudl not cause the light to come on.
    I have mine removed right now and the light stays off. Truck rides to high with no load..
    Nov 2013
    33
    It also feels like the car is being restricted while the compressor is running. What is the fuse labeled so I can try taking it out? Thanks again for all the help
  13. Remove Advertisements
