Rear Speakers Don't Work
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear Speakers Don't Work in Cadillac Escalade Forums; I have a 2003 Escalade EXT, replaced the stock radio with a Pioneer unit...everything worked fine for a couple of ...
    Nevada6372 is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade EXT
    Dec 2013
    1
    I have a 2003 Escalade EXT, replaced the stock radio with a Pioneer unit...everything worked fine for a couple of years...then the rear speakers stopped working...checked the fader in the unit, put it all the way to the back, no audio...only the fronts work...going to take it to get it checked out, but before I do, is there something as simple as a fuse that would power the rear speakers? Thanks.
    Eric
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    Re: Rear Speakers Don't Work
    I had a similar problem w/ my old avalanche, did you replace the rear speakers at some point? What happened in my case is the rear speaker wires were routed incorrectly and got snagged in the window and eventually after enough opening and closing of the window started to become damaged. However it could also be the amp.... you will need to get a meter on the HU output and the amp output and see where it's going dead.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    If factory Bose speakers try a aftermarket set and see if the problem goes away if not then the amp or adaptor is bad
    dahubby98's Avatar
    dahubby98 is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Sep 2013
    Missouri
    61
    Im thinking the amp may be out. The fronts will work without it but the back will not...
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by dahubby98
    Not really as I had my drivers speaker act up before I installed my infinity speakers and it was the speaker connection
    I haven't had a problem since hence why I suggested trying a aftermarket speaker
  8. Remove Advertisements
