Need help on Navigation on a 2004 Eacalade.
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Need help on Navigation on a 2004 Eacalade. in Cadillac Escalade Forums; Hi, guys, I need a big hepl on this.My 2004 Cady came with a Y91 amplifier but with no navigation ...
    vinniepn is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    Nov 2013
    10
    ExclamationNeed help on Navigation on a 2004 Eacalade.
    Hi, guys, I need a big hepl on this.My 2004 Cady came with a Y91 amplifier but with no navigation system, just a radio/cd/casette unit. I buy a Touch Screen GM navigation unit fron a 2007 Hummer 2 ( part # 15800000). The lab tested the unit and pass. Every thing was ok. I install the antenna and the new system and every thing was workink fine execpt that I have no audio. Navi ok, radio ok, cd ok but no audio, also no audio on Onstar neither. I went to the dealer to reprogram the new system and they say that the wiring conection are different and they can"t do nothig. Please, any way to fix this dilema? Any little help will be appreciated. Thanks.
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    352
    Re: Need help on Navigation on a 2004 Eacalade.
    Obviously you did not use the search feature. Search and you will find the answer There are multiple treads
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    The 15800000 radio is NON-LUX so it would be for vehicles without Y91 option. There are ways to make it work, but it sounds like you got the wrong radio.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by vinniepn
    All escalades have the y91 package radio and amp which are the lux versions of the factory system
    The hummer h2 dropped the lux radio system after 04 in favor of the non lux radio systems(cheaper)
    Yes they are different but its on the inside
    Sorry to say that you got the wrong radio for your truck
    Nov 2013
    10
    Thak you a lot guys. I will try to get the right one. Please, any suggestion for a good GM touch escreen Navigation System (part #) compatible with my Y91. Thanks in advanced.
    Mar 2011
    speedwell tn,
    11,884
    As long as the doner vehicle has the y91 rpo code you will be ok
    Just be wery about hummer amps as they go dead not long after so consider this a heads up should you need a replacement amp in the future
    Nov 2013
    10
    Thank you Cadillac man. I check on Ebay and they have a LUX GM navigation part # 15230099 with 90 days warranty. My Escalade came with the factory Y91 Amp. I'ts that the right part to Get? Thanks a lot for you help.
    Mar 2011
    speedwell tn,
    11,884
    It should work
    Nov 2013
    10
    Thank you Sr. Your help is very apreciated.
    Oct 2004
    352
    Read you will learn a lot
    Everything you need to know
    http://www.cadillacforums.com/forums...ade-touch.html
  13. Remove Advertisements
