2009 OEM Escalade Rims on 2002 EXT
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2009 OEM Escalade Rims on 2002 EXT in Cadillac Escalade Forums; Will they fit without rubbing? Also will that raise the height of the truck? Thanks...
    pellegrino is offline Cadillac Owners Member
    Nov 2013
    33
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by pellegrino View Post
    Yes they will fit and they will not change the height at all. They have thinner sidewalls on the tires and are approximately the same overall diameter. If you were not aware the tire pressure monitor sensors (TPMS) that come on 2007+ vehicles will not work with the older model vehicles. So unless you want a warning light constantly on, you might think about putting the correct sensors in before mounting them.
    Nov 2013
    33
    I was hoping it would raise the truck alittle i always thought they were alot higher than it seems. Ok thanks alot that would have been an issue do you know what to do before I mount them?
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    You can put bigger tires on that would provide a small lift.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by z0lt3c
    I did this on my 03 and now its almost at the same ride hight as my dads hummer h2
    Nov 2013
    33
    Could I take the sensors out of the 02 rims that I have now and put them in the 09 to get rid of that problem? Or should I just buy new ones?
    Mark Edward Morrison's Avatar
    Mark Edward Morrison is offline Cadillac Owners Fanatic
    Jun 2012
    419
    The batteries in the TPMS only last for a certain amount of years, I just replaced all of mine because I had a bad one. I got all brand new AC Delco sensors on Amazon or RickAuto for if I recall $35.00 a piece. Your already going to have the wheels off, might as well have brand new sensors on your new wheels....
    z0lt3c's Avatar
    Nov 2013
    Central NJ
    171
    Re: 2009 OEM Escalade Rims on 2002 EXT
    The TPMS batteries generally last 7 to 10 years, so if they are the original sensors I would concur with the previous poster to replace them. If, however, the TPMS sensors are not original, then they could very well still be within their useful life. I normally reuse them personally if there was no problem with them previously. They do make rebuild kits for the sensors, but these only address the seal and sensor condition, not the battery.
    Are you sure you even have a TPMS system in your 2002? My 2003 does not have such a system, I am not sure if it was a factory option or not.
    Mar 2011
    speedwell tn,
    11,884
    04 was the first year for the tpms from factory bound to be aftermarket
    My 03 dosen't have either
    Nov 2013
    33
    Im not sure but if they dont and the 09 rims do will that still set off a warning?
    Mar 2011
    speedwell tn,
    11,884
    If the truck has the tpms then yes it will
    If the truck doesn't have the tpms then no
    Nov 2013
    33
    Ok thanks!
    Nov 2013
    33
    Thanks everyone they fit perfectly
  16. Remove Advertisements
