What are the options for replacing the shocks/Autoride? 2005 Escalade
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, What are the options for replacing the shocks/Autoride? 2005 Escalade in Cadillac Escalade Forums; I have a 2005 Escalade and I'm thinking the shocks are getting old and in need of replacement. I have ...
    scottamarc is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade (Base)
    Nov 2013
    17
    I have a 2005 Escalade and I'm thinking the shocks are getting old and in need of replacement. I have been looking on ebay, lots of Arnott conversion kits that claim to clear the error codes from displaying. Has anyone gone this route?
    Has anyone had the dealer install this conversion kit? If not, where do you have it installed?
    I love my truck and want to keep it, willing to throw some money at the ride to make it smoother. It also seems like that auto-leveling compressor runs ALL THE TIME when someone is sitting in the back or there is cargo in the rear area. What's up with that?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Sounds like the shocks are leaking
    Take some soapy water and spray down the shock bladders while working the bumper up and down while watching for bubbles
    If there is any bubbles on the shocks they will need replacing soon
    To prevent the compressor from running like crazy if the shocks are leaking remove the relay on the outside of the underhood fuse box
    BDuncan is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    233
    Re: What are the options for replacing the shocks/Autoride? 2005 Escalade
    The very best option (although not the cheapest) is to purchase the exact OEM shocks that are manufactured by Monroe for GM. The Monroe shocks can be had for about $215-$225 each from Amazon, Rock Auto and many others. GM list price is close to $600 each. Any dealer or repair shop can install. Arnott does not and cannot rebuild OEM shocks (nor can anyone else). Arnott sells old worn rear shocks that have been sent in as cores or from junk yards, paints them and adds a new air bag. These are not rebuilt and only have a new air bag. Arnott also sell aftermarket standard shocks with a plug in that fools the Suspension ECM from setting a trouble code. These are quality shocks from Bilstein. However this completely dissables the auto ride and stibility control features of our trucks. There are also many other quality aftermarket shocks available but ONLY the Monroe/GM magnetic fluid shocks will maintain the autoride and stability control functions.
    Nov 2013
    17
    I want to get whatever will work with the Autoride and stability system, for sure. Is there any way to see which Monroe shocks to purchase? A list of part numbers for all 4 shocks?
    z0lt3c's Avatar
    z0lt3c is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade 6.0
    Nov 2013
    Central NJ
    171
    Quote Originally Posted by scottamarc View Post
    Best source for the Monroe's that I've found is Rockauto.com, you can use their parts locator to find the right noes. Also monroe's website has a parts lookup tool.
    If they have base length model;
    40034 "Rear; Escalade Base Model; w/ Electronic Suspension" $238x2
    40044 "Front; w/ Electronic Suspension" $238x2
    So you talking about $950 for the Monroes.
    With the Arnott/Bilstein kit you will maintain auto-leveling in the rear with the stock compressor and stock level sensors. You can call this "autoride" or a close copy there-of. This should be a consideration for the rear. However, for the front, there really is no equivalent to the electronically controlled dampening in the Monroe/OEM parts. All of the kits I've found just bypass any input from the front sensors. This is the harder area for me to justify a solution other then Monroe/OEM, put I am going to try a cheap kit shock/spring from strutmasters and see how it feels. It's not that hard to install front and rear shocks and if you can find a good indy, it should be no more then a 2 hour job.
    stanlrl is offline Cadillac Owners Member
    Nov 2013
    48
    3
    I'll hop in - so instead of buying the "GM OEM" that list for $450ish, you are saying the Monroe is a good replacement and I don't lose anything switching away from "GM OEM" parts? Appreciate the assistance!
    Disregard my comment - I just saw answer on other string I started.
    Disregard - just got answer on another thread.
    icaddy is offline Cadillac Owners Fanatic
    Sep 2012
    43
    137
    I think Arnott's shock is pretty good and price is actually cheaper. More important they have life time warranty.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by icaddy
    I got mine from them and the life time warranty is because of that
    I like them but I got my compressor brand new from my local dealer as I didn't want to splice the wiring of my truck
    z0lt3c's Avatar
    Nov 2013
    Central NJ
    171
    I've got the Arnott/Bilstein solution in the rear, so no argument from me, but the OP seemed to be concern w/ full OEM system integration.
    My bigger issues w/ Arnott, as I already mentioned, is they don't have an active solution for the front. The Arnott/Bilstein kit simply includes a bypass for the front sensors and ECU input.
    Nov 2013
    17
    Just so I understand, the Monroe shocks are totally compatible and work with the Escalade's Autoride and auto-leveling system. The is no "tricking" the computer or somehow bypassing the system? I think the $225-250 price is reasonable for Monroe, but not if I am losing the Autoride.
    Mark Edward Morrison's Avatar
    Mark Edward Morrison is offline Cadillac Owners Fanatic
    Jun 2012
    419
    Yes they are, I have them on my truck Monroe part# 40034 for the rear and #40044 for the front if you decide to do them as we'll. if you need a compressor also, I recommend the Dorman 949-000, it is an exact OEM replacement, plug and play. I bought and have all the above product on my truck and can tell you they all work AWESOME! I bought all the above parts at RockAuto and Amazon. You pay for quality. 😉
    Nov 2013
    17
    Thank you! That's what I will do. Great info!
    Quote Originally Posted by Mark Edward Morrison View Post
    darth frosty is offline Cadillac Owners Member
    Automobile(s): 04 escaled blue
    Jul 2011
    44
    4
    Good info
  16. #14
    8ball's Avatar
    8ball is offline Cadillac Owners Fanatic
    Automobile(s): '05 Escalade EXT
    Jul 2005
    Tampa, FL
    42
    216
    What s the load capacity on this shocks? I tow a 5,000 pound Trl and ever since I noticed my compressor doesn't come on anymore and come to find out the rear shocks rubber Round then is Ll torn up too. I want to see if I should do away with these air shocks and just go with the other after market shocks.
  17. #15
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by 8ball
    If the compressor isn't kicking on with a load then it is needing replacing
    I kept my truck stock and love the factory shocks
    Got the compressor from my local gm dealer and got the shocks from arnotts(got the "remanufactured" ones) truck is nice and stable at high speeds
  18. Remove Advertisements
