Results 1 to 6 of 6
Thread: Added a ton of motor work to my LQ9 in my 03 Escalade.........
    Guyz1996deville's Avatar
    Guyz1996deville is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 Escalade
    Jul 2005
    Milwaukee
    37
    540
    Hey everyone!! I haven't posted in a long time so I figured I would touch base. I have added a cam ( Comp Cam LS1 XR265HR-14 ), Gibson headers valve springs, valve seals, ported and polished the heads, as well as dyno tuned it all in. This paired with the Corsa cat back and Magnaflow high flow cats and the Volant cold air intake really paired wonderful. This truck is rockin now!!
    https://www.facebook.com/photo.php?f...=3&theater
    https://www.facebook.com/photo.php?v...=3&theater
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Awesome job
    Jul 2005
    Milwaukee
    37
    540
    Re: Added a ton of motor work to my LQ9 in my 03 Escalade.........
    I figured that I would post some of the past that I know works with a LQ9 6.0 2003 early.
    ARP-134-3609IHEAD BOLT SET EARLY BOTH HEADS
    CCA-13702-KITROCKER ARM BEARING KIT
    CCA-152LUBE 4 OZ PRO CAM/LIFTER
    CCA-26918-16HIGH PERFORMANCE VALVE SPRINGS
    CCA-54-412-11CAM
    CCA-7955-16PUSHRODS
    FEL-HS26192PTHEAD SET
    FEL-TCS45993LS-1 TIMING COVER GASKET SET
    Here is a sound bit I recorded.
    https://www.facebook.com/photo.php?v=10151690323143113&set=vb.541508112&typ e=3&theater
    B
    RAAaaaaaaappppPPPPPppp
  5. #4
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    The motor has a nice lope to it!
  6. #5
    Jul 2005
    Milwaukee
    37
    540
    The cam is mild enough for stop and go, as well as get up and go. It lopes pretty good in deed. I just wonder what is next. I do have a little trans work as well. Torque converter I would love to bump to 3000. I added plates in the trans already. i was getting a hesitation between 2-3 band at WOT. That with a body tune made it shift soooo much better. The Superchips Cortex has a nice feature for shift points and pressures.
    The cam is mild enough for stop and go, as well as get up and go. It lopes pretty good in deed. I just wonder what is next. I do have a little trans work as well. Torque converter I would love to bump to 3000. I added plates in the trans already. i was getting a hesitation between 2-3 band at WOT. That with a body tune made it shift soooo much better. The Superchips Cortex has a nice feature for shift points and pressures.&nbsp;<br><br>
    The cam is mild enough for stop and go, as well as get up and go. It lopes pretty good in deed. I just wonder what is next. I do have a little trans work as well. Torque converter I would love to bump to 3000. I added plates in the trans already. i was getting a hesitation between 2-3 band at WOT. That with a body tune made it shift soooo much better. The Superchips Cortex has a nice feature for shift points and pressures.&amp;nbsp;&lt;br&gt;&lt;br&gt;
  7. #6
    Nov 2013
    3
    Did u run a heavy enough came to need a stall converter I'm building my 05 ext right now doing a cam and stall followed up with a 150shot of giggle juice but looking at cam options
  • You may not post replies
