05 escalade pass side no heat
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05 escalade pass side no heat in Cadillac Escalade Forums; So I have an 05 escalade and pass side has no heat, found the blend door actuator and it wasn't ...
    devanwon is offline Cadillac Owners Member
    Automobile(s): 05 escalade
    Dec 2011
    35
    26
    So I have an 05 escalade and pass side has no heat, found the blend door actuator and it wasn't doing anything I moved it manually and it goes hot and cold on the
    Middle face vent beside the stereo nothing on the pass side vents or defrost or feet. Located the actuator on the upper side of the heater box didn't see it move at all
    Either no matter what I did on the controller. My question is what controls passenger heat for defrost and face vents? I know there is 3 actuators on the pass side heat box one on bottom on on pass side and one on top. How do I get to the one on top or the side cause it has to be one of those two. Any help I appreciated!
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Re: 05 escalade pass side no heat
    I think it is the Stepper Motor?
    Dec 2011
    35
    26
    This is what I'm talking about I'm calling it an actuator your saying stepper motor?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by devanwon
    It is called a actuator not a stepper motor(those are in the cluster
    Dec 2011
    35
    26
    So any ideas guys?
    Mar 2011
    speedwell tn,
    11,884
    So any ideas guys?
    Have you tried pulling the hvac fuse
    Pull the hvac fuse for two minutes
    Put it back in and turn the key to run(engine NOT running) for two minutes
    Turn the key off then start the truck it should force the system to calibrate itself
    If not then it would be best to get the system checked for codes
    My rear hvac system threw a over travel code and I had to replace the brain box as I got nothing but ice cold air in the winter(women hate cold air in the winter) also had to replace the temp door actuator as it failed at the same time(long and expensive story)
    Dec 2011
    35
    26
    The dealer ran it with no codes preset they said and they said that the could "see" all the actuators if that makes sense.. I'll try the have fuses tmrw and see if that works. Does anyone know which actuator controls the heat for the pass vents and defrost? Also if it's the top actuator on the heater box how do you get it
    Out? Again all help is appreciated guys!
    Mar 2011
    speedwell tn,
    11,884
    The dealer ran it with no codes preset they said and they said that the could "see" all the actuators if that makes sense.. I'll try the have fuses tmrw and see if that works. Does anyone know which actuator controls the heat for the pass vents and defrost? Also if it's the top actuator on the heater box how do you get it Out? Again all help is appreciated guys!
    If you want pm me and I will help out more with this
    Dec 2011
    35
    26
    Pm sent
    Dec 2011
    35
    26
    Going by the manual cadillacman sent me looks like my control module is bad. Is this common in these cars? Also does anyone in my area (Portland Oregon) have one that I can try to make sure It works?
    Also how do you reset the actuators? Thanks again
    Also how do you reset the actuators for when I replace the control module
    Mar 2011
    speedwell tn,
    11,884
    Going by the manual cadillacman sent me looks like my control module is bad. Is this common in these cars? Also does anyone in my area (Portland Oregon) have one that I can try to make sure It works? ---------- Also how do you reset the actuators? Thanks again ---------- Also how do you reset the actuators for when I replace the control module
    The control module can be bought at a salvage yard
    Resetting the system is done when power is applied and the key is on for 2mins
    Dec 2011
    35
    26
    Is the module going bad common?
    Mar 2011
    speedwell tn,
    11,884
    Rear yes front no
  16. Remove Advertisements
