Fuel Gauge readings wrong
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Fuel Gauge readings wrong in Cadillac Escalade Forums; On my '05 with 105,000 miles, when it was started up this morning the low fuel light was on and ...
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    On my '05 with 105,000 miles, when it was started up this morning the low fuel light was on and the gauge read that the tank was empty. Should be over 3/4! Then it moved up to 1/4 after a few miles then up to 1/2 a few miles later.
    Is it safe to say that the sender is going bad, or possibly it has some crud on it? Any recommendations to fix it?
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    Quote Originally Posted by caddydaddy
    On my '05 with 105,000 miles, when it was started up this morning the low fuel light was on and the gauge read that the tank was empty. Should be over 3/4! Then it moved up to 1/4 after a few miles then up to 1/2 a few miles later. Is it safe to say that the sender is going bad, or possibly it has some crud on it? Any recommendations to fix it?
    either way the tank has to come down, may as well replace it
