Nav radio wont come on
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Nav radio wont come on in Cadillac Escalade Forums; When I start my truck in the morning the temp is usually between 26-30 degrees and constantly getting colder well ...
    Txao1051's Avatar
    Txao1051 is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Feb 2013
    29
    98
    When I start my truck in the morning the temp is usually between 26-30 degrees and constantly getting colder well no matter how long I warm the car up the nav radio won't come on until I have been driving the car for about 5 min. Is there something I can do to make sure it comes on right away again. Last winter I never had this problem even when it was as cold as -20.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Do you get any music or chimes from the speakers?
    Does the display do anything
    I would check the radio fuse in the under hood fuse box
    Txao1051's Avatar
    Feb 2013
    29
    98
    Quote Originally Posted by the cadillac man
    Do you get any music or chimes from the speakers? Does the display do anything I would check the radio fuse in the under hood fuse box
    Chimes come on but the lights In the unit don't even come on. The fuses are all good. It looks like the unit is dead. You know when you power te unit down the time is still displayed? Well it doesn't even do that!
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Txao1051
    Try pulling the radio fuse for a bit and see if it resets the radio
    I had this happen to me except the lights stayed on no matter if the head lights were on or not pulling the radio fuse for a bit fixed it
    Txao1051's Avatar
    Feb 2013
    29
    98
    Try pulling the radio fuse for a bit and see if it resets the radio I had this happen to me except the lights stayed on no matter if the head lights were on or not pulling the radio fuse for a bit fixed it
    Tried that this morning to no avail. I took it out for about 5 min when the truck was on...
    Mar 2011
    speedwell tn,
    11,884
    Then its dead completely then
    Txao1051's Avatar
    Feb 2013
    29
    98
    It comes on after driving the truck for approximately 5 minutes
    Usually the exact same spot on my drive.
    Mar 2011
    speedwell tn,
    11,884
    It comes on after driving the truck for approximately 5 minutes ---------- Usually the exact same spot on my drive.
    That's odd
    Have you checked the wiring harness the plugs in the back of the radio to see if its loose
    It could be a wiring issue or ground somewhere if its working some time
    Txao1051's Avatar
    Feb 2013
    29
    98
    That's odd Have you checked the wiring harness the plugs in the back of the radio to see if its loose It could be a wiring issue or ground somewhere if its working some time
    Yea it's usually on mornings were temp is below 35 degrees
    Txao1051's Avatar
    Feb 2013
    29
    98
    So this morning I got in and started it up. The radio came on right away!!! Yay!!!! Spoke to soon As soon as I changed the channel it turned off. It came back on exactly 20 minutes later. Any ideas?
    Could it be the PAC OEM gm24 that I have to use as a converter for my amp?
    Mar 2011
    speedwell tn,
    11,884
    So this morning I got in and started it up. The radio came on right away!!! Yay!!!! Spoke to soon As soon as I changed the channel it turned off. It came back on exactly 20 minutes later. Any ideas? Could it be the PAC OEM gm24 that I have to use as a converter for my amp?
    Not sure but it might be as both the radio and amp is worked off the class 2 data bus
    Txao1051's Avatar
    Feb 2013
    29
    98
    I removed that PAC converter and everything is working again. Hmmm guess I won't be recommending that product to anyone
    Mar 2011
    speedwell tn,
    11,884
    It may be bad and needs replacing
  16. Remove Advertisements
