Check Engine Light ON..reads Code P0430!!!! What is this??
Results 1 to 14 of 14
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Check Engine Light ON..reads Code P0430!!!! What is this?? in Cadillac Escalade Forums; I need some expertise here from the pro's... Ok so this morning I get the check engine light so I ...
    sosatyme72 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Escalade ESV
    Mar 2013
    44
    188
    Ok so this morning I get the check engine light so I take it Auto Zone so they can read the code and it came up as P0430,
    code reader says it came up twice.
    The guy explained that this code is:
    Catalyst efficiency low-bank 2
    Now my truck is a 2003 ESV with 116k miles and I just did a tune up with new plugs, wires, air mass sensor about 3 months ago...
    What would I need to get this fixed? how pricey will this be?? thanks guys!
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Re: Check Engine Light ON..reads Code P0430!!!! What is this??
    Not sure but it looks like your catalytic converter may be on its last leg.
    Mar 2013
    44
    188
    So there are 2 sides that we have in our truck left/side. How do we know which side is bad or do we replace both. Been lookign around and seems pricsy about 250-300 a side for direct fit.
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    Actually, $300 a piece sounds relatively cheap. Converters are an expensive part of your exhaust system. I don't know which side bank 2 would be. Hopefully one of the techs here will see this and give you some advice. Does your truck sound any different? It would be nice if the code was just thrown due to an exhaust leak. If it were mine, I would probably pay a pro to diagnose it and get a repair quote. That way you would know for sure. It is possible it could be something else, and you don't want to pay for new cats if you don't need them.
    I have heard of them failing before 100K miles but that's pretty rare. My Subaru has the original exhaust on it (other than the muffler) and it's almost at 200K.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    792
    One suggestion, check the post cat 02 sensor on the side giving you the code, maybe swap left and right post cat sensors to see if the code moves to the other side. GM swapped out a cat on my Corvette under warranty only to find out that it was the post 02 sensor that was flaky after the code returned.
    One thing you mentioned is you replaced the MAF. Was the old one bad? It doesn't take long to ruin cats with a bad MAF sensor, so it might just be the cat if you did run around with a bad MAF.
    Mar 2013
    44
    188
    yeah i guess i have to see from a tech and see what they say and hope it something minor. The truck sounds fine to me havent noticed anything out the ordinary as of now.
    Quote Originally Posted by Retrax View Post
    is that something fairly easy I can do or do I have to put the car on lift? Yeah teh maf was bad so I had to replace it. I rode with it maybe a few weeks until I got it replaced but that was like 3 months ago and wasnt driving far just locally.
    Quote Originally Posted by wake View Post
    kantgetnun is offline Cadillac Owners Member
    Automobile(s): 2003 escalade ext
    Sep 2013
    41
    13
    My money will be on the cats. That's what mine was. Shortly after the code popped on mine It was down on power ran like crap. I threw a boroscope down the cats and they looked good but when I pulled them off all kinds of stuff started falling out. Put the new cats on and it ran like a dream.
    Mar 2013
    44
    188
    did you have to replace both or just the 1 side? how much did it run u to fix?
    Quote Originally Posted by kantgetnun View Post
    Sep 2013
    41
    13
    i ended up doing both sides. i found the magnaflow stainless direct replacements on auto zones website and they had a 20%cupon code going on. so i got them for 420-ish shipped and put them on myself
    wake's Avatar
    Sep 2003
    Stafford, VA
    792
    Quote Originally Posted by sosatyme72 View Post
    It would be easier on a lift or at least on some front ramps to give you some sliding room, just moving the O2 sensors side to side. But since you mentioned the bad MAF, I'd also suppose your cats are bad. It doesn't take long to ruin them as a bad MAF will likely cause the engine to dump gas, flooding the cats. I'll bet you had horrible gas mileage with that bad MAF. Last time I had that happen to me on my Camaro I went from 27 mpg down to 5-7 mpg, got it to the shop the same day both times but at only 12 miles away I burned more than 2 gallons of gas doing it, quite a lot to ask from the cats.
    Mar 2013
    44
    188
    ok so I was going to bring it to shop this weekend but now check engine light came off...is this normal should it stay on until I get it fixed?? is it ok now, false alarm?lol
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Get the codes pulled as now they are history codes but will still help figure out what caused the light to come on
    Mar 2013
    44
    188
    ok but is the check engine light suppose to stay on or is it normal to go away?
    Quote Originally Posted by the cadillac man View Post
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    If the issue is intermittent then yes it will go off but it may be best to still get the codes
  17. Remove Advertisements
