Cloudy Headlights?
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Cloudy Headlights? in Cadillac Escalade Forums; I'm new to the Cadillac world, Just picked up a 2005 ESV Platinum in White diamond (awesome rig!). I was ...
    tla11384 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Escalade ESV Platinum
    Oct 2013
    32
    8
    Cloudy Headlights?
    I'm new to the Cadillac world, Just picked up a 2005 ESV Platinum in White diamond (awesome rig!). I was looking at the headlights and notice that the top of both headlights have a slight haze to it? Are the lights made like that or is that due to the HID lights?
    Thanks
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    349
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    916
    Re: Cloudy Headlights?
    Try this thread as well, start at post #2 by shore, he dilutes the rubbing alcohol which is the way I do it as well, works great.
    http://www.cadillacforums.com/forums...t-pulling.html
    *Note* if you do this during the winter months where you cannot leave the headlamp assembly outside in the sun for a few hours to dry out, I put ours over a heat register in the house overnight, then replace them back in the vehicle in the morning.
    Oct 2013
    32
    8
    Awesome Thanks
    Carvone is offline Cadillac Owners Fanatic
    Automobile(s): 07 STS 1SG / 10 STS 1SG / 17 XTS
    Nov 2008
    Florida
    55
    274
    I just used plain old water, swished it around and poured it out, been clear for 3 years now. Stick your wifes hair dryer in one of the holes on low heat for half hour or so and it will be all dry.
    Feb 2010
    916
    Wow 3 years, I have a hard time going 6 months before the little bit haze starts to bug me.
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    I used 1/2 cup distilled water with 1/2 cup rubbing alcohol in each headlight. Distilled water won't leave water marks when it evaporates. I immediately switched to LED DRL's and now I have no more problems.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I had this issue and after swapping the drl's to led no problems since
    I also changed the high beams to hid
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Quote Originally Posted by Carvone View Post
    That's all I did on mine, worked like a charm.
    Quote Originally Posted by jnrsesv View Post
    What kind of bulbs you using in your assemblies?
    I had some haze come back after a few months but I had crappy plastic bulbs in there for the markers, DRLs, etc. Swapped them to glass and no more hazing inside. I'm thinking the plastic must be cooking off and clouding up the headlight assemblies.
    Feb 2010
    916
    Quote Originally Posted by wake View Post
    I am using what the manual calls for, I cannot member what the # is, but they are glass bulbs.
    wake's Avatar
    Sep 2003
    Stafford, VA
    812
    Ok, was curious since a lot of my original clear bulbs were actually plastic. I also ended up replacing the orange bulbs which were glass in my case with new orange colored glass bulbs. The paint had burned on the stockers and made me wonder if they contributed to the cloudiness.
    Nov 2008
    Florida
    55
    274
    Maybe that had something to do with mine staying clear for so long, I did this procedure when I first bought it and replaced all the bulbs with new while I was in there. The old bulbs were flaking off in my hands and the new ones were much brighter.
    Mar 2011
    speedwell tn,
    11,884
    Mine are doing that on the blinkers going to switch to LEDs and forget the whole worry
  16. #14
    Oct 2013
    32
    8
    i switched to LED bulbs and the work for about 30 min and both DRL cut out and stop working. I checked the bulbs with other connections, its not the bulbs, or any of the the DRL fuses. Any suggestions??? all other lights work fine.
    Quote Originally Posted by the cadillac man View Post
    did have to use resistors? I also installed led for the blinkers but they started hyper flashing.
  17. #15
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by tla11384
    i switched to LED bulbs and the work for about 30 min and both DRL cut out and stop working. I checked the bulbs with other connections, its not the bulbs, or any of the the DRL fuses. Any suggestions??? all other lights work fine. ---------- did have to use resistors? I also installed led for the blinkers but they started hyper flashing.
    Sounds like the truck doesn't like the leds
  18. Remove Advertisements
