Too much play in both front wheels.
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Too much play in both front wheels. in Cadillac Escalade Forums; Hello, was changing out my tires yesterday and noticed that both wheels had quite a lot of play in them. ...
    Baba_HT's Avatar
    Baba_HT is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade
    Oct 2013
    53
    14
    Hello, was changing out my tires yesterday and noticed that both wheels had quite a lot of play in them. I was able to shake them and move them alot. i dont think this is right.
    is it a steering issue? when i drive i do not notice it much at all. but there is defintely a lot of play there.
    any advise appreciated.
    Baba_HT
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Play in which direction? 12:00-6:00, or 3:00-9:00?
    Baba_HT's Avatar
    Oct 2013
    53
    14
    I believe its more 12 to 3
    Sep 2010
    East Boston MA.
    29
    26,325
    That wasn't one of the options, lol. Does it move with your hands at the top and bottom, or on the sides?
    Baba_HT's Avatar
    Oct 2013
    53
    14
    Hmm I believe side to side
    Sep 2010
    East Boston MA.
    29
    26,325
    Ok, side to side is a steering linkage issue. Tie rod ends are the most likely.
    Baba_HT's Avatar
    Oct 2013
    53
    14
    Thanks.
    How much am I looking at to get fixed. Or can I do it solo. I am average tinkerer. I replace fluids and do brakes myself. Nothing beyond that.
    Skier-24 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV, White Diamond Pearl
    Jun 2013
    Chesterfield, VA
    56
    277
    Re: Too much play in both front wheels.
    You can do it. Except for the front end alignment. When I changed the ones on my Tracer, I made a mark on the tie rod and measured to the center of the tie rod end. After screwing the new ones in to that exact same measurement, I tightened everything back up. Some people recommend counting threads on the tie rods but that only works when all parts are identical. It has been over five years, tires wear perfectly and still no front end alignment.
    Forgot to mention a couple of things:
    The tie rod ends were about to drop out when I bought the car. That would cause a total loss of steering control.
    They only cost about $15.00 each. Well worth it.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    804
    Quote Originally Posted by Skier-24 View Post
    Good advice on measuring versus counting threads. I noticed on a different vehicle that the replacements were a different length from the originals.
    Outer tie rod ends are easy to change, inners though are a different story. Most times you need a tie rod tool to get the inners as there isn't enough room to work where they bolt to the steering.
    For the OP, if you have a helper then lie under the truck and have them turn the steering wheel slowly from side to side. You don't have to start the truck, you're not turning the wheels just the steering wheel. You can look and feel for slop in the tie rods as they work the wheel from inside. Inners from what I understand don't go bad as often so replacing the outers is a good and easy start to hopefully fix your problem.
    Baba_HT's Avatar
    Oct 2013
    53
    14
    Thanks for great advice. I purchased the rods and will install myself around mid week. Will keep u posted. .
    Cheers
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    Quote Originally Posted by Baba_HT
    Thanks for great advice. I purchased the rods and will install myself around mid week. Will keep u posted. . Cheers
    mine had a little play, i traced to the inner tie rods i greased the zurks and its good now, also check wheel bearing as well
  14. Remove Advertisements
