Rear Wiper "thumps" and doesn't turn
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear Wiper "thumps" and doesn't turn in Cadillac Escalade Forums; My rear wiper motor "thumps" but doesn't turn. When I say thumps it makes that sort of sound. The pump ...
    BlueOvalKid is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum
    Jun 2013
    41
    26
    The pump works and gets fluid but the wiper doesn't turn.
    I got another pump from salvage and hooked it up and it does the same thing.
    I know it's possible I have 2 bad motors but what are the odds? Is there anything else I should check?
    I checked the connector and am getting 12v on/off with the switch, the pump works so the only thing left if the motor, right?
    I tried to rotate each motor with pliers the arm hooked up but it won't budge. I think they are both frozen and bad.
    Any other thoughts?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by BlueOvalKid
    My rear wiper motor "thumps" but doesn't turn. When I say thumps it makes that sort of sound. The pump works and gets fluid but the wiper doesn't turn. I got another pump from salvage and hooked it up and it does the same thing. I know it's possible I have 2 bad motors but what are the odds? Is there anything else I should check? I checked the connector and am getting 12v on/off with the switch, the pump works so the only thing left if the motor, right? I tried to rotate each motor with pliers the arm hooked up but it won't budge. I think they are both frozen and bad. Any other thoughts?
    Do you have a multi meter if yes check for 12 volt at the harness
    If you get power then the motors are bad
    Jun 2013
    41
    26
    Re: Rear Wiper "thumps" and doesn't turn
    Ok, I have tried 3 different motors and all behave exactly the same.
    I have 11.8v on the supply wire and a good ground at the connector.
    Turn the wiper switch to 1 or 2 and the voltage drops to ~ 7v. It seems like I have a voltage issue.
    The pump works just fine and squirts fluid.
    I have checked the 3 hatch switches and they all seem to be fine and give the proper "open" indication if I disconnect them.
    Do I have a bad switch? Is there something else I'm overlooking?
    Mar 2011
    speedwell tn,
    11,884
    Ok, I have tried 3 different motors and all behave exactly the same. I have 11.8v on the supply wire and a good ground at the connector. Turn the wiper switch to 1 or 2 and the voltage drops to ~ 7v. It seems like I have a voltage issue. The pump works just fine and squirts fluid. I have checked the 3 hatch switches and they all seem to be fine and give the proper "open" indication if I disconnect them. Do I have a bad switch? Is there something else I'm overlooking?
    Replace the switch as that sounds like the culprit
    Jun 2013
    41
    26
    Well, a brand new dash switch from GM didn't solve it either.
    What else am I missing?
    Jun 2013
    41
    26
    Any other ideas?
    One other thing that I just found out, due to winter weather, is that my rear defroster also does not melt the snow. The switch lights up and cycles after a few minutes but does nothing to heat the glass and melt the snow/ice.
    Are these related?
    Mar 2011
    speedwell tn,
    11,884
    Any other ideas? One other thing that I just found out, due to winter weather, is that my rear defroster also does not melt the snow. The switch lights up and cycles after a few minutes but does nothing to heat the glass and melt the snow/ice. Are these related?
    That sounds like a loose ground as the rear defroster has to have a solid ground to work
    Let me check my service manual and see where the ground is for the rear defroster
    Jun 2013
    41
    26
    Any information?
    Mar 2011
    speedwell tn,
    11,884
    Any information?
    Sorry I have been busty and haven't had time to check
    Espritv8 is offline Cadillac Owners Member
    Automobile(s): 03 Escalade
    Dec 2009
    29
    I ahve the exact same problem here. seems to be pretty common.
    pmartell12's Avatar
    pmartell12 is offline Cadillac Owners Fanatic
    Automobile(s): 2015.5 black premium, sold my black 2003 ESV
    Jul 2010
    London, Ontario, Canada, 11450
    40
    141
    mine thumps as well,,, occasionally it will do a half sweep, then stop.... when i open the glass, it returns to it's "closed" position.... is it a sensor for if the glass is open?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by pmartell12
    There is a sensor that tells the tbc that the door or window is open my guess it also works the wiper as mine goes into park position when I open either(window or hatch)
    Dec 2009
    29
    Yep checked that, but it doesn't seem to be the problem. I'm thinking a bad ground, but don't know where to look at first. Defrost is not working either.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Espritv8
    Both not working is surely a ground issue
    There is a splice pack behind the right rear quarter panel
    The ground point is also behind the same quarter panel
    Check both and see if the issue goes away
    Also check the battery ground cable as it can also cause some crazy stuff
  17. #15
    Dec 2009
    29
    Thanks, I will take a look soon and keep you posted
  18. Remove Advertisements
