Front end growling noise after brand new diff but only under decel???
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Front end growling noise after brand new diff but only under decel??? in Cadillac Escalade Forums; Ok here goes. I had a what I thought was the notorious front end growl, but only Under decel, it ...
    kantgetnun is offline Cadillac Owners Member
    Automobile(s): 2003 escalade ext
    Sep 2013
    41
    13
    Under decel, it starts getting noticeable above 40mph and is very annoying by 60mph. Seemed like the transfer case may have been making some noise as well. I bought brand new rebuilds from a very reputable company, I put both units in today
    and
    Couldn't wait to go for a ride and hear a nice quiet caddy....... Noise was still there! I am at a complete loss and at my wits end! So to reiterate, the noise is only on
    Decel. If I push the throttle pedal slightly is goes away. Noise is there whether the
    Truck is coasting in neutral or in drive, with or without traction control or with the
    Towing on or off. The only way it goes away is to slightly push the throttle whil still slowing down. As if I'm removing the "negative load" it sounds like a rotational
    Noise kind of like a drive shaft is rubbing on something, but I have been all over
    This truck and I can't find anything that is making any contact.
    Thanks for any help
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by kantgetnun
    Ok here goes. I had a what I thought was the notorious front end growl, but only Under decel, it starts getting noticeable above 40mph and is very annoying by 60mph. Seemed like the transfer case may have been making some noise as well. I bought brand new rebuilds from a very reputable company, I put both units in today and Couldn't wait to go for a ride and hear a nice quiet caddy....... Noise was still there! I am at a complete loss and at my wits end! So to reiterate, the noise is only on Decel. If I push the throttle pedal slightly is goes away. Noise is there whether the Truck is coasting in neutral or in drive, with or without traction control or with the Towing on or off. The only way it goes away is to slightly push the throttle whil still slowing down. As if I'm removing the "negative load" it sounds like a rotational Noise kind of like a drive shaft is rubbing on something, but I have been all over This truck and I can't find anything that is making any contact. Thanks for any help
    Tranny whine mine does this
    It could also be the ac compressor(it will moan also)
    Sep 2013
    41
    13
    Re: Front end growling noise after brand new diff but only under decel???
    Quote Originally Posted by the cadillac man View Post
    the noise is not a whine. its pretty loud, almost what a drive shaft would sound like if it was making contact with somthing. it really sounded like a bad front end, but i guess i ruled that out.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Quote Originally Posted by kantgetnun View Post
    Axle half shafts maybe? Rear end, mistaken for a noise from the front?
  7. Remove Advertisements
