Results 1 to 13 of 13
Thread: xm vs. sirius
    cashmereDTS is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac DTS, 2004 Cadillac Escalade
    Apr 2009
    Ontario, CAN
    97
    xm vs. sirius
    Hi all.
    I was just wondering what the difference is between the Sirius SCC1 tuner and the Audiovox SXV200 XM tuner other than thefact one is for sirius and one is for xm.
    Since my 04 escalade did not come with sat radio (there is no xm tuner box behind the glove box) I wanted to add it.
    I'm a little skeptical of buying a used factory xm tuner because who knows how long it will last and I would have to get it's memory cleared so it could learn my vin, otherwise I would get the "xm locked" message.
    Thoughts/comments?
    Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by cashmereDTS
    Hi all. I was just wondering what the difference is between the Sirius SCC1 tuner and the Audiovox SXV200 XM tuner other than thefact one is for sirius and one is for xm. Since my 04 escalade did not come with sat radio (there is no xm tuner box behind the glove box) I wanted to add it. I'm a little skeptical of buying a used factory xm tuner because who knows how long it will last and I would have to get it's memory cleared so it could learn my vin, otherwise I would get the "xm locked" message. Thoughts/comments? Thanks
    I have tuners with both services(got used) and both offer the same service and programming but the channel lineup is different between the two
    Factory tuners aren't a good used purchase
    Apr 2009
    Ontario, CAN
    97
    Re: xm vs. sirius
    Quote Originally Posted by the cadillac man View Post
    Thanks for the reply.
    I was thinking the same thing. What are you using as a head unit to control the tuner?
  5. #4
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    Thanks for the reply. I was thinking the same thing. What are you using as a head unit to control the tuner?
    channels changed a while back, should be the same now
  6. #5
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wesyder
    Uh I will have to check next time I use it
    I have a Sirius tuner controlled via the factory head unit
    Here is a link to the tuner I have
    http://www.amazon.com/gp/aw/d/B001P61WSM
  7. #6
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    Uh I will have to check next time I use it ---------- I have a Sirius tuner controlled via the factory head unit Here is a link to the tuner I have http://www.amazon.com/gp/aw/d/B001P61WSM
    channel lineup is also available on their site
  8. #7
    Mar 2011
    speedwell tn,
    11,884
    I know but I haven't been on the site for either in some time
  9. #8
    Apr 2009
    Ontario, CAN
    97
    Re: xm vs. sirius
    Is your factory head unit a touch screen nav unit? If so, does the controll come from the left side buttons of head unit or on screen touch screen choices?
  10. #9
    Mar 2011
    speedwell tn,
    11,884
    Yes I have the touch screen nav unit
    The controls are on the screen work presets the hard button select the source and audio and setup menus
  11. #10
    Apr 2009
    Ontario, CAN
    97
    Re: xm vs. sirius
    Thanks. But I have another question lol.
    Does the model number/brand/ of the tuner dictate what information the head unit receives? (You gave a link to a Sirius SIRGM1 tuner and you said that the touch screen is used to pick and operate functions for adjusting. I'm looking to get a Sirius SCC1 as part of the following package;
    http://www.ebay.com/itm/Sirius-satel...ht_5923wt_1050
    Do you think the tuner (Sirius SCC1) will send the same messages to a GMT 800 TNR, allowing the touch screen to be functional in making adjustments like your set up?)
    My apologies if this question is too particular.
  12. #11
    Mar 2011
    speedwell tn,
    11,884
    Thanks. But I have another question lol. Does the model number/brand/ of the tuner dictate what information the head unit receives? (You gave a link to a Sirius SIRGM1 tuner and you said that the touch screen is used to pick and operate functions for adjusting. I'm looking to get a Sirius SCC1 as part of the following package; http://www.ebay.com/itm/Sirius-satel...ht_5923wt_1050 Do you think the tuner (Sirius SCC1) will send the same messages to a GMT 800 TNR, allowing the touch screen to be functional in making adjustments like your set up?) My apologies if this question is too particular.
    Those add on units work the same reguardless of the factory radio
    I know as I have had both styles of radio
  13. #12
    Apr 2009
    Ontario, CAN
    97
    Re: xm vs. sirius
    I see what you are saying. Just wondering which tuner would be more compatible in our vehicles. Although older, the SIRGM1 was specifically designed for our vehicles compared to the SCC1 which is a universal tuner. After talking to a hardware technican at Sirius, she recommended the SIRGM1. She did not speak very highly of the SCC1 because of its less than desirable track record for compatibility and longevity. Having said that, there are probably much more SCC1 tuners in use meaning the potential for more faulty units just based on numbers.
  14. #13
    Mar 2011
    speedwell tn,
    11,884
    I have the sirgm1 tuner and it works no problem my dad has one in his h2(already installed before he got the truck)and it works great and no issues
    I did have to replace the harness for mine but I got a bad harness when I got mine
  • You may not post replies
