What type of anti-freeze
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, What type of anti-freeze in Cadillac Escalade Forums; I believe my water pump is beginning to leak and need to add water and some anti-freeze. What type of ...
    wilbanks51 is offline Cadillac Owners Member
    Automobile(s): 2006 escalade
    May 2011
    65
    45
    I believe my water pump is beginning to leak and need to add water and some anti-freeze. What type of anti-freeze does this 2006 escalade call for?
    thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    A 50/50% mix of either DEX-COOL or the all makes/all models "green stuff", And distilled water. They both perform exactly the same, and they can be mixed as long as the bottle of the all makes/all models stuff says so.
    The change interval for either should be 2 years, 3 max, regardless of what the owners manual or bottle says.
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    912
    Re: What type of anti-freeze
    I will second MoistCabbage, but just to make sure you have to make sure the "green stuff" is compatible with the DEX-COOL!
    To avoid any confusion down the road just use a 50/50 mix of DEX-COOL again as MoistCabbage stated.
    Be sure to check the condition of your pulleys, tensioners and your small AC Serpentine Belt located to the front lower left of the motor.
    rfishoutofwater is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade EVS Platinum Rip Tide Blue
    Jul 2012
    44
    164
    Changing water pump is simple. Just had to do mine a couple months ago and took under and hr to R&R. Easiest one I've ever done. No special tools. Bought my WP at Oreillys for around $100 bucks can't recall of hand but it was way cheaper than dealer and has a lifetime warranty.
    cadikarl is offline Cadillac Owners Member
    Automobile(s): escalade
    Oct 2013
    51
    I always use premix for convenience and to ensure proper mixture.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I use the pre mix also
  9. Remove Advertisements
