Problem with engine acceleration jerk cold
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Problem with engine acceleration jerk cold in Cadillac Escalade Forums; cadi site.JPG Hello My name is guillaume I live in France and I has a Cadillac escalade 2000. I encounter ...
    mgc59's Avatar
    mgc59 is offline Cadillac Owners Member
    Automobile(s): Cadillac escalade 2000 motors 5.7vortec
    Oct 2013
    France
    34
    21
    cadi site.JPGHello
    I encounter a problem for the cold start.
    My cadillac has a lack of cold gas (it makes shock)
    After 10 minutes it turns impeccable.
    -I changed the spark plugs and spark plug wires.
    -Ignition is new (msd)
    -New Mass Air Flow Sensor
    If you have an idea
    Thank you Guillaume
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by mgc59
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=150057"/>Hello My name is guillaume I live in France and I has a Cadillac escalade 2000. I encounter a problem for the cold start. My cadillac has a lack of cold gas (it makes shock) After 10 minutes it turns impeccable. -I changed the spark plugs and spark plug wires. -Ignition is new (msd) -New Mass Air Flow Sensor If you have an idea Thank you Guillaume
    Sounds like the fuel pump is getting weak
    mgc59's Avatar
    Oct 2013
    France
    34
    21
    Re: Problem with engine acceleration jerk cold
    I have the problem that during 5 - 10 time after nothing more
    mgc59's Avatar
    Oct 2013
    France
    34
    21
    I changed;
    Rotor and distributor
    That works now
    Mar 2011
    speedwell tn,
    11,884
    I changed; Rotor and distributor That works now
    Try the stock wires again and see if the issue continues
    mgc59's Avatar
    Oct 2013
    France
    34
    21
    I have more problem since the change rotor /distributor
    Mar 2011
    speedwell tn,
    11,884
    Is the check engine light on?
    If yes then get the codes pulled and report back
    mgc59's Avatar
    Oct 2013
    France
    34
    21
    I found the solution.
    I changed distributor and rotor
    Everything's fine now,
    Mar 2011
    speedwell tn,
    11,884
    I found the solution. I changed distributor and rotor Everything's fine now,
    The other distributor and rotor must have been bad
    mgc59's Avatar
    Oct 2013
    France
    34
    21
    Normal wear
    I installed the brand MSD
  13. Remove Advertisements
