First post...and big problem...
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, First post...and big problem... in Cadillac Escalade Forums; Hello everyone! I have a 2003 ext, this is my first post after lurking for quite a while. Im having ...
    kantgetnun is offline Cadillac Owners Member
    Automobile(s): 2003 escalade ext
    Sep 2013
    41
    13
    Hello everyone! I have a 2003 ext, this is my first post after lurking for quite a while. Im having some issues, about a week ago I had a p0430 code pop, i cleared it to see if it would happen again...it did, so after reading a few things here I switched the rear o2's side to side and also threw a boroscope down the cats, they looked ok not perfect but not bad either. the rear o2 code never popped up again, since i bought the truck a few weeks ago i decided to do a tune up, plugs, wires, fuel filter, and sea-foamed the fuel tank. everything was fine for a couple days...then a p0302 code flashed but not lit solid, (i was driving a bit hard when this happened) so i cleared it and waited to see if it would happen again. it did but this time a p0300 popped, first flashing then solid. within about 10 miles of driving back home it started to run really rough. felt like it wasn't going to make it home. I changed plugs again and checked all the wires. pulled the fuel rails and cleaned the injectors( didn't have them professionally done just sprayed them down really well). cleaned maf, changed fuel pressure regulator. Im getting 50 psi of fuel pressure with the key on, 48 psi at idle and 58 psi under throttle with no load. it runs rough all across the board, idle, under throttle with no load and even worse with a load. also swapped coils, no change. bank 1 looks to be running super lean. Im at a bit of a loss. I even drained all the fuel and replaced it with fuel from a different gas station just to be safe.
    thanks in advance for any help/opinions
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,814
    Quote Originally Posted by kantgetnun
    Hello everyone! I have a 2003 ext, this is my first post after lurking for quite a while. Im having some issues, about a week ago I had a p0430 code pop, i cleared it to see if it would happen again...it did, so after reading a few things here I switched the rear o2's side to side and also threw a boroscope down the cats, they looked ok not perfect but not bad either. the rear o2 code never popped up again, since i bought the truck a few weeks ago i decided to do a tune up, plugs, wires, fuel filter, and sea-foamed the fuel tank. everything was fine for a couple days...then a p0302 code flashed but not lit solid, (i was driving a bit hard when this happened) so i cleared it and waited to see if it would happen again. it did but this time a p0300 popped, first flashing then solid. within about 10 miles of driving back home it started to run really rough. felt like it wasn't going to make it home. I changed plugs again and checked all the wires. pulled the fuel rails and cleaned the injectors( didn't have them professionally done just sprayed them down really well). cleaned maf, changed fuel pressure regulator. Im getting 50 psi of fuel pressure with the key on, 48 psi at idle and 58 psi under throttle with no load. it runs rough all across the board, idle, under throttle with no load and even worse with a load. also swapped coils, no change. bank 1 looks to be running super lean. Im at a bit of a loss. I even drained all the fuel and replaced it with fuel from a different gas station just to be safe. thanks in advance for any help/opinions
    possibly a bad ignition coil by your description
    Sep 2013
    41
    13
    Re: First post...and big problem...
    I bought a new coil and switched it to each cylinder and no change
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,814
    oops didnt see that in you first post, which plugs did you use
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    The p430 code means catalyst system low efficiency bank 2
    The p0300 code means a engine mifire detected
    Both codes point to the cats going bad
    I have seen this happen before in a ford truck
    It kept bogging out and wanted to die under load and never wanted to idle right
    It also showed it was running lean(due to the excessive back pressure)
    The cats was replaced the problem was solved
    it went through three sets of speak plugs before it was fixed but it would throw you back in the seat afterwards
    I hate to be a bearer of bad news and this being your first thread on here but it is the truth
    Ps if it is one cat bad just replace the one but it is best to replace both as the other may fail at a later date
    Sep 2013
    41
    13
    I had a feeling on the cats after the p0340 popped. I went ahead and ordered the manga flow direct
    Replacements. They should be here in the morning. We will see then! Hopefully no permanent damage to
    The engine was done.
    Mar 2011
    speedwell tn,
    11,884
    I had a feeling on the cats after the p0340 popped. I went ahead and ordered the manga flow direct Replacements. They should be here in the morning. We will see then! Hopefully no permanent damage to The engine was done.
    How long was it like this?
    If not long(eg less then a month) then i wouldn't worry
    If not sure then I would get the engine checked at a gm dealer(a good gm dealer)
    Sep 2013
    41
    13
    it all started happening this past monday, probably 10-15 miles on it after the p0300 popped along with 20-30 minutes of running in the garage for diagnostic time.
    Mar 2011
    speedwell tn,
    11,884
    Ok then you shouldn't have to worry about damage to the engine as long as you get the cats replaced ASAP
  12. Remove Advertisements
