a/c blower on the blink
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, a/c blower on the blink in Cadillac Escalade Forums; 03 EXT first, i had the heated drivers side/normal pass side-havent fixed it yet as its no big deal, id ...
    wetneck is offline Cadillac Owners Member
    Automobile(s): 03 EXT
    Mar 2013
    58
    03 EXT
    first, i had the heated drivers side/normal pass side-havent fixed it yet as its no big deal, id turn it on and off a couple/few times and it
    would go back to normal
    tonight, after work, fan was on high, tried to turn fan down, wouldnt,tried numerous times
    hit power button, only switched air flow to floor
    turned off key, fan stayed on
    pulled both harnesses out of climate control in dash, fan still wouldnt stop
    had to pull relay under hood to get fan to stop
    air was still cool
    any suggestions or is it off to the tech to pull codes ?
    thanks in advance
    blower motor resistor OR blower motor module ?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wetneck
    03 EXT first, i had the heated drivers side/normal pass side-havent fixed it yet as its no big deal, id turn it on and off a couple/few times and it would go back to normal tonight, after work, fan was on high, tried to turn fan down, wouldnt,tried numerous times hit power button, only switched air flow to floor turned off key, fan stayed on pulled both harnesses out of climate control in dash, fan still wouldnt stop had to pull relay under hood to get fan to stop air was still cool any suggestions or is it off to the tech to pull codes ? thanks in advance ---------- blower motor resistor OR blower motor module ?
    Its the blower control module
    Its under the dash next to the blower behind the hush/kick panel
    Remove three screws(1 is going to be a pita to get to)
    Remove the hush/kick panel
    The module is right next to the blower
    FYI when the system is shut off the floor position is the default rest position for the mode door
    Mar 2013
    58
    Re: a/c blower on the blink
    i called caddy today to get price
    they told me there are only 3 components to the system, blower fan, dash control and resistor under glove
    i was under the impression there was a resistor AND a control module under glove
    are they using another name ?
    can someone clarify for me please ?
    Mar 2011
    speedwell tn,
    11,884
    i called caddy today to get price they told me there are only 3 components to the system, blower fan, dash control and resistor under glove i was under the impression there was a resistor AND a control module under glove are they using another name ? can someone clarify for me please ?
    They may be thinking of some of the older systems(which does use the resistor pack)
    The controls you use to adjust the system is the control module the works the whole hvac unit
    The blower module is what the control module uses to control the blower motor
    The manual hvac units use a resisitor pack for the blower the auto climate system uses a blower module
    I hope that was helpful
    Mar 2013
    58
    Would you be able to poat a pic of what i need before i buy the wrong part ?
    Mar 2011
    speedwell tn,
    11,884
    I will get a pic of the service manual for you
    Mar 2013
    58
    well bought the part.... i saw on the dealer screen it did say module.....
    but cant believe you have to cut/splice into a factory harness !
    Mar 2011
    speedwell tn,
    11,884
    well bought the part.... i saw on the dealer screen it did say module..... but cant believe you have to cut/splice into a factory harness !
    I know its crazy
    Mar 2013
    58
    ok.... ac fine for months....yesterday in the morning i bumped temp up and lowered fan... halfway thru my ride drivers side started blowing hot again....now normal again today
    is the module going out again ???
    doubt i kept receipt but are they factory warrantied at all ???
    Mar 2011
    speedwell tn,
    11,884
    ok.... ac fine for months....yesterday in the morning i bumped temp up and lowered fan... halfway thru my ride drivers side started blowing hot again....now normal again today is the module going out again ??? doubt i kept receipt but are they factory warrantied at all ???
    Warrenty depends on the dealer(mine don't cover electronic stuff)
    Sounds like the temp door actuator is failing
    Mar 2013
    58
    Thanks for the quick heads up, where might i find this one in the truck ?
    Mar 2011
    speedwell tn,
    11,884
    Passenger side bottom of the dash
    Remove the hush/kick panel(3 screws)
    FYI the screw near the tranny hump is a pain to get to
    The actuator is pretty much in plain view
    WARNING do NOT power up anything while doing this or you risk damaging the actuator while its removed
    Two or three screws(I forget) hold it in place and remove the harness
    Go to the dealer to get this as most parts stores are clueless(been there before)
    Mar 2013
    58
    havent had the issue happen again, should i assume its on it way out and replace ?
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Could have been a one time glitch
    If it does it again replace it
  17. #15
    Mar 2013
    58
    its done it 2x in the last month
    i see MANY listed everywhere as many GM vehicles use them so i called Cadi and was told there is an upper AND lower ?? yes ?? any way to tell which is bad ?
  18. Remove Advertisements
