Results 1 to 14 of 14
Thread: Which sensor is this???? 2005 Escalade ESV
    Jan 2004
    49
    I just finished replacing my valve cover gaskets and I noticed this sensor absolutely coated in oil. I didn't think the valve cover gaskets looked all that bad when I replaced them, so I am curious if maybe this sensor is leaking oil. My thoughts are it is either the oil pressure sending unit or a coolant temp switch. Either way, if anybody knows, please tell me. As you can see, it is in the front top of the driver's side head right next to the power steering pump. Any help would be appreciated!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Looks like the coolant temp sensor. The oil on it came from above it, not from it.
    Jan 2004
    49
    If it is the CTS, that is definitely the case. I haven't noticed any oil smell in the short amount of operating temp driving I have done. There appeared to be some random seepage to the exhaust manifold in various places, but nothing as exorbitant as what you see on that particular sensor. So far so good!
  5. #4
    wesyder's Avatar
    wesyder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    Quote Originally Posted by MoistCabbage
    +1..
  6. #5
    Jan 2004
    49
    I still detect oil burning off the exhaust. Looks like it is coming from the top front of the engine. I have to re-remove the shrouds to get a more specific location. Any ideas? Does the intake manifold carry an oil channel that could be seeping?
  7. #6
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    Quote Originally Posted by jtkirk5598
    did you clean the engine afterwards?
  8. #7
    Jan 2004
    49
    No, but I have since. Still appears to be oily up front. I had a friend with the 6.0 L in a Chevy van, and he had a problem where he had the intake gasket cause massive oil burning, so that's why I want to know if oil pressure flows though the intake. Up front I saw the camshaft position sensor. That whole area of the engine is coated in sludge. I will be taking the plastic shrouds off the engine this weekend and Re-examine where the leak is.
  9. #8
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    63
    76
    Re: Which sensor is this???? 2005 Escalade ESV
    That is the cts sensor. The camshaft sensor is in the rear next to the oil pressure sensor, looking at the engine from the front the oil is on the right and cam on the left. The oil leak you have is from the valley cover under the intake plenum. If you take off the intake make sure you replace the Knock sensors as well as they are known to go bad. there is a seal under them as well.
  10. #9
    Jan 2004
    49
    That makes sense. I was unable to get a good look at the sludge covered sensor. Does GM sell a gasket kit specific to this repair? If so, do you have the part number? Thanks for your valuable input!
  11. #10
    Nov 2011
    BOYNTON BEACH,FL
    63
    76
    They do but its not a kit. Ask for lifter valley cover gasket and knock sensor gaskets.
  12. #11
    Jan 2004
    49
    I see I can get just the lifter valley gasket and obviously the intake gasket as well. How many knock sensors does the 6.0L have in 2005?
  13. #12
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    The 6.0 has 2 no matter what year
  14. #13
    Jan 2004
    49
    Turns out the oil seepage was remnants from bad valve cover gaskets. After thoroughly cleaning the engine, the leak has not returned. Everything is as it should be. Thanks for helping me learn about the GM V-8 gassers.
  15. #14
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    cool
  • You may not post replies
