Fluid change
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Fluid change in Cadillac Escalade Forums; I'm looking to get all the fluids changed on my 03 Escalade AWD. I mean ALL the fluids. Has anyone ...
    Stingray23 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Oct 2008
    NY
    179
    Fluid change
    I'm looking to get all the fluids changed on my 03 Escalade AWD. I mean ALL the fluids. Has anyone had this done? And how much would something like this cost me?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Stingray23
    It depends on the brand of fluids used and where it is done
    Oct 2008
    NY
    179
    Re: Fluid change
    Well, I have a someone I know doing it at the local Mavis. I might just go to the local auto store and buy all the fluids myself and have him them change it out. I'm going with synthetic oil.
    Mar 2011
    speedwell tn,
    11,884
    Good idea but make sure you watch as some will sneak and put a different kind(eg congenital fluids)and no tell you
    Oct 2008
    NY
    179
    Re: Fluid change
    Should I get GM OEM fluids or other? I'm definitely doing Mobil 1 synthetic oil and filter though.
    Mar 2011
    speedwell tn,
    11,884
    It depends on what you prefer
    Me I use the gm fluids and haven't had a problem
    Primetime1267 is offline Cadillac Owners Member
    Automobile(s): 2013 Escalade
    Sep 2012
    Sarasota, Fl
    44
    54
    I know I like to use AMSOIL in all of our cars and the boat. But I'm a dealer so it costs a little less than buying it off the self at the store. It feels great knowing u have changed everything all at once and then u have an excellent starting point to keep track of ur intervals.
    Sent from AutoGuide.com Free App
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Re: Fluid change
    Quote Originally Posted by Stingray23 View Post
    The only thing that I'd be careful to scrutinize in the transfer case fluid. In my 05 it specifies Dexron III-H fluid which isn't available anymore. I had to hunt around a bit to find out about the H specification. Mobil1 ATF I found at Autozone lists H specification on it's label. There's a lot of discussion about using the newer GM Dex VI in the transfer case and I've seen warnings against it and arguments for it. I found one exception to using Dex VI in the transfer case but that is a couple of years old. In automatics Dex VI is fine to mix with older Dex III, the GM bulletin I found though makes exception for that in the case of transfer cases and manual transmissions where Dex III-H is specified.
    Having all the fluids done at a shop will likely cost you around $400-$500, the transmission change with filter is usually at least $100 of that cost. I went that route one time on a different vehicle when I lived in an HOA community where you weren't allowed to work on your vehicles, even in your own driveway. And in my case I had to go back to the Jiffy Lube where I had it done because they put the wrong fluid in my transfer case. The shop didn't put the available only through GM fluid in and the transfer case got noisy right off the bad.
    Oct 2008
    NY
    179
    Re: Fluid change
    Thanks for the replies.
    Oct 2008
    NY
    179
    Re: Fluid change
    So, my truck is going in tomorrow morning at my local Mavis. This is what I am getting done:
    -Synthetic engine oil and filter
    -Air filter
    -Coolant
    -Change fluid of front and rear transfer cases
    -Transmission fluid and filter
    Anything else I am missing or should do?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    ALL fluids?
    You're forgetting brake and PS fluid, and diff oil.
    Oct 2008
    NY
    179
    Re: Fluid change
    I had the brakes done last year. How about the axles?
    I'm gonna do plugs and wires too
    Sep 2010
    East Boston MA.
    29
    26,323
    Yeah, axles, diffs, same difference.
  16. Remove Advertisements
