First Caddy, Many Questions 2000 Escalade
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, First Caddy, Many Questions 2000 Escalade in Cadillac Escalade Forums; Hello gentlemen and ladies, my name is Tyler and I just purchased a 2000 Escalade with 90k miles. It is ...
    ChiTownTy is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade
    Sep 2013
    29
    9
    Hello gentlemen and ladies, my name is Tyler and I just purchased a 2000 Escalade with 90k miles. It is extremely clean, rust free and runs like a champ. There is little that it needs to be perfect, everything is in great working condition, even the after market auto starter. I have a few questions and your answers/ opinions would be greatly appreciated!
    1. Most importantly what parts are known to fail first on these vehicles? At 90k miles, what should I look to replace first?
    2. I seem to have a couple instrument cluster lights and 4x4 switch lights burnt out. I searched, cant find a thread teaching me how to tear apart the dash to get to those.
    3. I am an avid user on the BMW forums and they are quite helpfu, stocked with information. This forum is not organized very well with all generations of escalade conglomerated into the same page. The stickie threads also dont have much information pertaining to the 2000 escalade. Maybe someone can steer me in the right direction. Thanks!!
    mitch2264's Avatar
    mitch2264 is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade Platinum
    Dec 2007
    ATL
    79
    Re: First Caddy, Many Questions 2000 Escalade
    Hi Tyler,
    Congrats on your Escalade! A 2000 would be the older bodystyle (matches the 96-99 Tahoe/Yukon) if I am not mistaken. I believe you would have the 5.7 liter (350 CI) engine with a 4L60E transmission. I had a 99 Suburban that was this platform and I also currently have a 97 Sierra truck, same set up engine & transmission wise. I can tell you that the intake manifild gaskets are notorious for failure---not a matter of "if", but "when". With yours having 90K on the clock, it has [I]probably [I]been replaced. Do keep an eye out for that. The only other areas of grief would be the a/c compressor is prone to leaks (google HT6 Belly leaker). I had to replace on each of mine. The 4L60E transmission can casue giref too. Mine blew out at 60,000 on the Suburban--it was maintained and not abused! However the truck seems okay at 130,000 on the clock.
    As far as help with the 4X4 switches, you may have better results with a Chevy truck forum. My personal favorite forum is at chevytalk--
    Your new ride sounds sweet!
    Thanks,
    Mitch
    CT's_Ride is offline Cadillac Owners Member
    Automobile(s): Escalade
    Aug 2013
    5
    I have a 2000 as well that i am trying to take care of some issues. I do like that they share a lot of the same gm parts. My 4x4 selector also has the lights out, BUT when i press the panel down around the switches the 2wd indicator lights up. So i do not think it's the bulb but maybe a loose connection? I haven't had the chance to get in there yet, but hopefully I can find some answers on the forums somewhere.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by CT's_Ride
    Replace the switch as they are prone to wear out with age
    Aug 2013
    5
    Thanks for the tip Cadillac man, that's what I'll do.
    Sep 2013
    29
    9
    Yes thank you for that bit of info Cadillac man.
    How about any ideas for this rough idle I am having? It feels and sounds like a vacuum leak but clears up as soon as I accelerate. It was not there when I bought the car but today it triggered a check engine light. Could this be the notorious intake manifold gaskets you mentioned? My buddy is going to hook it up to his scanner tomorrow and we will try to diagnose. Any tips from you guys would be helpful too.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by ChiTownTy
    Yes thank you for that bit of info Cadillac man. How about any ideas for this rough idle I am having? It feels and sounds like a vacuum leak but clears up as soon as I accelerate. It was not there when I bought the car but today it triggered a check engine light. Could this be the notorious intake manifold gaskets you mentioned? My buddy is going to hook it up to his scanner tomorrow and we will try to diagnose. Any tips from you guys would be helpful too.
    Pull the intake ductwork off and clean the throttle body and the rough idle will clear up(been there done that) I had mine die on me when I was in the middle of the road as I was turning onto another road(not fun)
    Two clamps hold the intake ductwork in place listen those and the ductwork should slip of the intake box and the throttle body
    Now the check engine light will have a code so get the codes and report back and I will help to find out what it is
    Sep 2013
    29
    9
    Thanks allot sir! I appreciate it! I should scan it by friday, im pretty busy tomorrow with the bears game and all.
    BEAR DOWN!
    Sep 2013
    29
    9
    So I scanned my car today Cadillac guru, maybe you could tell me what im looking at.
    We came up with error codes po155 and po300. I believe the first one is the oxygen sensor, not sure which, and the po300 code is for a misfire. Maybe you could elaborate on that one. Thanks man.
    Mar 2011
    speedwell tn,
    11,884
    So I scanned my car today Cadillac guru, maybe you could tell me what im looking at. We came up with error codes po155 and po300. I believe the first one is the oxygen sensor, not sure which, and the po300 code is for a misfire. Maybe you could elaborate on that one. Thanks man.
    P0155 is H02S heater performance bank 2 sensor 1
    P0300 is engine misfire detected
    Sounds like a 02 sensor is malfunctioning and causing a misfire due to inaccurate readings from that sensor
    I think it is the left front sensor(left manifold forward of the convertor)
    Sep 2013
    29
    9
    Cool thanks man. I hope I can figure it out with the description you gave me. Are there 4 oxygen sensors on these vehicles??
    Mar 2011
    speedwell tn,
    11,884
    Yep two per side
    Sep 2013
    29
    9
    So my truck has been running great since the o2 sensor replacement, thanks again. My concern now is during this cold weather and the transmission kind if knocking when switching from drive to reverse and park and such...I'm use to driving stick so I don't get any of that smacking feedback from automatic transmissions. Am I worrying to much? Shifts perfectly smooth while driving through gears. Is it just because it is 20 degrees out? I want to change my tranny fluid eventually because I didn't get any history with the car and I don't know if it's been done. How should I go about this? I'm assuming there would be some gaskets to change as well
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Unless its leaking I wouldn't worry about the seals
    The tranny fluid and filter should be changed if you tow a lot or the fluid is dark
    FYI just have the fluid and filter changed do not have the tranny flushed as it am cause negative effects(seen where some had the tranny fail due to that)
  17. #15
    Sep 2013
    29
    9
    Tranny fluid changed and I already noticed a huge difference. Not like it was super rough before, but it seems stress free now.
    Another issue, my heat in my cabin does not seem to be getting as hot as it should and my water temp gauge is reading a continuous 100 degrees. Could my thermostat be stuck open not allow my engine to heat up to the right temperature? Today it's like 6 degrees in Chicago, and I can't go on any longer.
    Thanks for your time Cadillac Man!!
  18. Remove Advertisements
