2004 EXT, truck bed cargo light problem?
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2004 EXT, truck bed cargo light problem? in Cadillac Escalade Forums; Anyone ever have a problem with the truck bed cargo light not working. Press dash board light switch on and ...
    timski is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Jan 2013
    Baton Rouge. La
    51
    4
    Anyone ever have a problem with the truck bed cargo light not working. Press dash board light switch on and dash board light comes on
    saying that its on, but no light. Check bulb with ohm meter and its good. Check voltage at light socket plug and no voltage present.
    There is no fuse indicated for this light in the manual. Any Suggestions?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by timski
    Check the tbc fuses
    I will check my wiring diagrams to see if there is a fuse for that light if it ain't shared with another curcuit
    Edit update I looked and didn't see any but still check the fuses
    Also make sure everything else in the truck works as that would help to pinpoint which fuse might be the culprit
    If it turns out it ain't a fuse it could be a bad or lose ground for the lights
    Also try a different bulb sometimes they may look good and check out fine on a multi tester but still be bad(seen it before)
    Also make sure the dome override button isn't pushed in(not sure if that has anything to do with the light in question or not)
