Ball joint replacement
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Ball joint replacement in Cadillac Escalade Forums; Hello guys. I have a problem putting the lower ball joint in a 1999 escalade 4x4. I have the large ...
    thorner1968 is offline Cadillac Owners Member
    Sep 2013
    48
    Hello guys. I have a problem putting the lower ball joint in a 1999 escalade 4x4. I have the large c-clamp ball joint tool ..I've heated the knuckle up and placed the ball joint in the freezer. Still doesn't go in straight.. Please please any responses are greatly appreciated
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    804
    Re: Ball joint replacement
    I've done a few of these. What I ended up doing was cleaning out the inside of the knuckle with a wire brush or steel wool. I coat the new ball joint with dish soap to make it slippery and crank the ball joint in slowly. The soap trick always made getting it back in much easier in my experience.
    Skier-24 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV, White Diamond Pearl
    Jun 2013
    Chesterfield, VA
    56
    277
    I would probably go more abrasive and use plumber's emory cloth. Get all the rust and corrosion out.
