Results 1 to 13 of 13
Thread: Cold Start Multiple Cylinder Misfire
    jedidiah012 is offline Cadillac Owners Member
    Automobile(s): 05 Escalade
    Oct 2011
    40
    5
    I have a 2005 Escalade 6.0L with 109k miles. The truck has run flawlessly up through two weeks ago, now has developed multiple cylinder misfire and flashing engine light. This only happens after the vehicle sits overnight or at least 10 hours (normally doesn't do it after a 9 hour work day, but the temp here in TX doesn't generally go below 90 until evening). This clears up after warming up and doesn't come back until it sits for long enough. No other codes have shown up yet. I have run through a fresh tank of gas and tried some fuel additive as well, but no luck. Any thoughts?
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    Quote Originally Posted by jedidiah012
    Possible seeping injector filling a cylinder with fuel while sitting, then when you start, that cylinder misfires until it gets the excess fuel out
    Oct 2011
    40
    5
    Re: Cold Start Multiple Cylinder Misfire
    That's a good thought, but I think that would mainly affect one cylinder, right?
  5. #4
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    True
  6. #5
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    That would, yes, but i have seen many random or multiple misfire codes stem from one cylinder, for your sake i would hope its only one cylinder
  7. #6
    Skier-24 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV, White Diamond Pearl
    Jun 2013
    Chesterfield, VA
    56
    279
    Keep a close eye on your oil. Smell it. If it is leaking into the cylinders, gas can get past the rings and dilute the oil.
  8. #7
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by Skier-24 View Post
    Or even better, have an oil sample analyzed by someone like Blackstone Labs. They can tell you how much fuel is getting in the oil, if any.
  9. #8
    Oct 2011
    40
    5
    Thanks for the input. I would think that there should be some misfiring after sitting any amount of time if it were fuel leaking into a cylinder. Also, I just changed the oil a couple days ago and it was the right consistency and smell, no signs of fuel contamination.
    I have two thoughts at this point. First, I was talked into quad tip platinum plugs when I changed them about 6 months ago, which I think was a mistake. The truck hasn't been quite as peppy since. I think I will trade them out for some stock AC Delco's.
    Second, I'm thinking that it might be an almost bad sensor, not quite bad enough to get a separate code, but just bad enough to cause some issues. I have heard that bad O2 sensors can cause cold misfires, not sure if that is true or not. I might just go ahead and start changing them too.
  10. #9
    Mar 2011
    speedwell tn,
    11,884
    Get those crap plugs out of your truck and get some gm professional iridium plugs(I got those and my truck is smooth)
    Now you need a tech-2 or a scanner that can read data streams from the sensors(such as the 02 sensors) but most cases I seen the 02 sensors fail it causes the truck to act different
    I wonder if you have a bad coil for that plug as those also can cause misfire codes
    Find out which plug it is and try a different coil pack
  11. #10
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    63
    76
    You need to have the truck scanned,if the multiple misfire is on one bank 2468 or 1357 you have a bad catalytic converter. When the check engine light flashes your supposed to shut the engine down. the truck has a right and left converter. They can be tested with a vacuum gauge. If they are bad you will need to replace o2 sensors as well.
  12. #11
    Oct 2011
    40
    5
    All of your input has been great, thanks!
    Here's the update...
    Changed out the Bosch plugs for stock Delcos and its fixed. Not only is the misfire fixed, but my gas mileage has improved significantly too! For the first time in 30k miles (about 25k of which was on the original Delcos) I'm getting 14/18 rather than 12/15! Consider changing out your originals sooner than later as my fuel economy was between 10-12/14-15 since 70k miles.
    Thanks all
    Jed
  13. #12
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    Thanks all
    Jed
    Yeah if i would of known, the bosch would have been first to go
  14. #13
    Mar 2011
    speedwell tn,
    11,884
    Thanks all
    Jed
    Bosch sucks
    I got gm professional iridium plugs and couldn't be happier(I was getting the same mileage before I did my tune up)
  • You may not post replies
