AC not cooling at idle and engine getting hot
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, AC not cooling at idle and engine getting hot in Cadillac Escalade Forums; Hey guys, My wife has to wait in line to pick my kids up from school for 30-45 minutes everyday ...
    7m34life is offline Cadillac Owners Member
    Automobile(s): Escalade
    Aug 2011
    Woodward,OK
    34
    17
    Hey guys,
    My wife has to wait in line to pick my kids up from school for 30-45 minutes everyday and her Escalade hasn't ever cooled very well idling and yesterday while waiting in line it was 105 outside and her car got up to 250 degrees and she shut the AC off and the temperature slowly came back down. I got in it after work and drove it for about 30 minutes and the AC worked fine driving but horrible at idle and it never got hot as I never just let it sit. Checked the antifreeze and it's full.
    What could cause my AC to get hot and my engine?? Fan clutch??
    Thanks,
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by 7m34life
    Hey guys,
    Thanks,
    It is possible the fan clutch will cause that
    It sounds like the fan clutch isn't engaging like it should
    The fan should put out a lot of air and can even be felt under the truck with the hood closed
    Aug 2011
    Woodward,OK
    34
    17
    Re: AC not cooling at idle and engine getting hot
    I was just watching the fan run and it seems like it's running ok at idle and when I shut the vehicle off it free spins a little but the fan isn't super easy to spin by hand. You can definitely tell it has some resistance.
    Mar 2011
    speedwell tn,
    11,884
    How much air flow is it putting out at idle?
    You really can't tell by looking if the clutch is bad on the fan but the way your truck is behaving it is most likely the fan clutch
    It should engage at low speeds and disengage at high speeds(truck speed not engine rpms)
    Have you cleaned around the radiator? Sometime debris builds up in there and impedes the air flow
    Aug 2011
    Woodward,OK
    34
    17
    No sir I have not cleaned around it. I did look around it on the backside and it looked pretty clean. If the fan clutch is cheap enough I'll just buy one and hopefully be done with this.
    Thanks for the input.
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    convert to electric
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bigirb2002
    convert to electric
    Do you know what it takes to do the conversion and you only gain maybe 4-5 hp anyway then you can't just get any replacement PCM should yours fail
    Glad to help if you still need help then just post
    Pollo432 is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Sep 2013
    28
    1
    Believe it or not my wife's escalade does the exact same thing. She's been out of town for a while, we're actually headed home at the moment and will tackle this issue tomorrow. Going highway speed does yours stay at a constant 190-210? Mine will drop down to 175-185. I'm going to start with the t-stat. The cheapest and quickest. If that doesn't help I will convert to factory e-fans.
    Mar 2013
    31
    119
    mine came electric. didnt know some came with a clutch fan
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,814
    That may be the 5.3 engines with the clutch fan
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wesyder
    On the 03 both engines have a clutch fan
    mitch2264's Avatar
    mitch2264 is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade Platinum
    Dec 2007
    ATL
    79
    Hope ths helps! From the GM Website, the 2005 and up models got the E fans:
    New for 2005
    The model year 2005 brings subtle refinements. The primary change is a new, premium instrument cluster with bright chrome rings around gauges and more detailed graphics. In addition, new burled walnut trim replaces traditional Zebrano trim. All models receive a bright chrome exhaust tip.The vehicle also will receive an all-new cooling system with two electric cooling fans, and the charging system also has been upgraded with a new 160 amp alternator and regulated voltage control. This will help improve A/C performance. Riptide, a teal blue metallic exterior paint, replaces Arrival Blue.
    bigirb2002 likes this.
    Mar 2013
    31
    119
    ^^^^^^^^^ thanks man learned something. wonder if its worth converting older models to the electric setup.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Thing to it is do you want to have to have a special order PCM
  17. #15
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    352
  18. Remove Advertisements
